Vincent Douce Posted April 23, 2022 Share #1 Posted April 23, 2022 Advertisement (gone after registration) hey i have noticed that when i try to focus on parallel lines, line guitar strings, i can not "superpose" to make it right in the telemetric viseur, (the tiny rectangle) the strings ||| appear with an other angle like /// is it normal ? Link to post Share on other sites More sharing options...
Advertisement Posted April 23, 2022 Posted April 23, 2022 Hi Vincent Douce, Take a look here focus on guitar strings . I'm sure you'll find what you were looking for!
jaapv Posted April 23, 2022 Share #2 Posted April 23, 2022 Quote Question: I come from an autofocus camera background. What is the best way to get good focus on an M camera? The M works the same way as any rangefinder camera, the central patch in the viewfinder is your focusing tool. It is important to look through the viewfinder in the optical axis. Looking into the camera skewed will result in inaccurate focus. The first thing to do is to ascertain that you can see the rangefinder patch properly. A correct match between the rangefinder and your eye is even more important than it is using an SLR. Leica sells corrective diopter lenses. Determining which one you need - if any- can be done by going to your optician and holding his try-out lenses between your eye and the viewfinder. The one that allows you to see the rangefinder patch and framelines sharply is the correct one. Order the nearest value from Leica. In a pinch you can use over-the-counter reading glasses for this test. If your eyes need special corrections, you can use your spectacles, provided you can see clearly at 2 metres distance ( the virtual distance of the rangefinder patch). Note that the background will be at background distance,so your eye should ideally be able to accomodate over the distance differential. However, there is some tolerance here. For special cases there are viewfinder magnifiers. They can help, especially with longer and fast lenses and they can give confidence, but they can also be not very useful; they cannot correct errors in the focusing mechanism or your eye, in fact they magnify them. Also, one loses contrast and brightness. Leica offers a 1.25x one and a 1.4x. These need diopter correction like the camera, but often of a different value than the camera viewfinder. There are also third-party magnifiers, sold by Japan Exposures, that include a variable diopter correction. 1.15x and 1.35x. For patent reasons they cannot be sold in the USA and Germany for use on a Leica camera, but they can be purchased for use on for instance a rifle scope. Basically, for an experienced user, magnifiers are not needed and will only lower contrast and brightness, but many users do like and use them. Once the viewfinder is corrected optimally, there are three methods of focusing, in ascending order of difficulty aka training. 1. The broken line method. Look for a vertical line in the image and bring it together in the rangefinder patch to be continuous. 2. The coincidence method. Look for a pattern in the image and bring it together to coincide. This may lead to errors with repeating patterns. 3. The contrast method. Once you have focus by method 1. or 2. a small adjustment will cause the rangefinder patch to "jump" into optimum contrast. At that point you have the most precise focussing adjustment. Side remarks: If you try focusing on a subject emitting polarized light like a reflection it may happen that the polarizing effect of the prism system in the rangefinder will blot out the contrast in the rangefinder patch, making focusing difficult. In that case rotate the camera 90 degrees to focus. You must make sure that the string that coincides is the same string, not its neighbour. You are probably seeing perspective, if the guitar is parallel to the camera, this will not happen. 2 Link to post Share on other sites More sharing options...
evikne Posted April 23, 2022 Share #3 Posted April 23, 2022 If I understand you correctly, I guess you are seeing the strings crossing each other ( XXXXX ), because the small picture in the focus patch has a slightly different angle than the big picture in the viewfinder. This is normal, and exactly like it should be. The focus is where the lines are crossing each other. You will see that the crossing areas are moving up or down when you turn the focus ring or move the camera closer or further away. I tried to take a photograph with my iPhone through my camera's viewfinder to illustrate (which turned out to be quite difficult) . Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/331850-focus-on-guitar-strings/?do=findComment&comment=4423286'>More sharing options...
jaapv Posted April 23, 2022 Share #4 Posted April 23, 2022 That is exactly what I meant with perspective. If the strings are in a parallel plane to the camera this will not happen. Thanks for illustrating. 1 Link to post Share on other sites More sharing options...
Vincent Douce Posted April 23, 2022 Author Share #5 Posted April 23, 2022 thanks very much both of you now, i understand that the focus is on the point where the strings (the "real" ones and the "virtual" ones) are crossing have a good day Vincent 1 Link to post Share on other sites More sharing options...
