I am interested to know why those features that are not in the M11 manual are not discussed wider: for example,
- user profiles continue to be deleted and possibly corrupted
- camera resetting to factory default for no reason
- mysteriously setting the ISO to 12500 as default
- erroneously overriding the shutter speed to higher than that set via the top plate dial.
- etc.
if I google these I get nothing. When I visit my Leica dealer, I am told they are well known issues.
Leica - resist the temptation to walk the route of denial and dishonesty. We will walk away.
It should tell you something that you find nothing in Google - Leica users are not the type to remain silent if there is an issue.
A dealer is not infallible; I would go for a second opinion by Leica Customer Service if I were you, and, to be honest, user error cannot be ruled out. Maybe you can tell us a bit more: for instance: do you save your user profiles?
I have user profiles active for 2 month.. they are still there after firmware update.
My understanding is that deleted profiles are caused by camera reset.
some function can be set by the touch screen even not set on top..
I can only think the internal battery is empty and the insert battery is stored outside. I can think of any other reset option.
Lots of problem are caused by incompatible SD cards...
You probably should tell us more.. every situation is different.
