Dave in Wales Posted April 4, 2022 Share #1 Posted April 4, 2022 Advertisement (gone after registration) Link to post Share on other sites More sharing options...
Advertisement Posted April 4, 2022 Posted April 4, 2022 Hi Dave in Wales, Take a look here When 28mm isn't quite 28mm . I'm sure you'll find what you were looking for!
Hans-Dieter Gülicher Posted April 4, 2022 Share #2 Posted April 4, 2022 I have noticed simmilar "automatic" effects with ACR. As a result most I am working manually. Hans Link to post Share on other sites More sharing options...
marchyman Posted April 4, 2022 Share #3 Posted April 4, 2022 I think the title of this thread isn't quite accurate. The uncorrected image is wider than 28mm. Guestimates from when the Q was first released said around 25mm if my memory is correct. The corrected image (and the lens was designed for those corrections) is closer to 28mm. See, for example, I suspect the Q2 is the same as the Q. Link to post Share on other sites More sharing options...
Bazookajoe Posted April 5, 2022 Share #4 Posted April 5, 2022 Nothing new here. The lens was designed that way. Viewing raw files in some post processing software gives you the option of seeing the full files before correction. Using SDC (software distortion correction) allows the designers to keep the size of the lens smaller than it otherwise would have been. Have you ever heard of such a wide lens with such a small filter size? The 28mm, for all intents and purposes, is a 28mm. Not natively, but it is when used the way it was intended. 1 Link to post Share on other sites More sharing options...
Dave in Wales Posted April 5, 2022 Author Share #5 Posted April 5, 2022 2 hours ago, Bazookajoe said: Nothing new here. The lens was designed that way. Viewing raw files in some post processing software gives you the option of seeing the full files before correction. Using SDC (software distortion correction) allows the designers to keep the size of the lens smaller than it otherwise would have been. Have you ever heard of such a wide lens with such a small filter size? The 28mm, for all intents and purposes, is a 28mm. Not natively, but it is when used the way it was intended. Informative, thank you. Link to post Share on other sites More sharing options...
Alentejo Posted April 13, 2022 Share #6 Posted April 13, 2022 Hi, I'm new with my Leica Q. I just took a DNG and jpeg and imported them into Affinity. They have both the same AoV. How can I achieve (use) the wider angle in RAW (DNG)? Thanks for Your help. Link to post Share on other sites More sharing options...
Anbaric Posted April 13, 2022 Share #7 Posted April 13, 2022 Advertisement (gone after registration) 5 minutes ago, Alentejo said: Hi, I'm new with my Leica Q. I just took a DNG and jpeg and imported them into Affinity. They have both the same AoV. How can I achieve (use) the wider angle in RAW (DNG)? Thanks for Your help. Did you try turning off Lens Correction in the Lens tab in the Photo persona before hitting Develop? Link to post Share on other sites More sharing options...
Alentejo Posted April 13, 2022 Share #8 Posted April 13, 2022 vor 3 Stunden schrieb Anbaric: Did you try turning off Lens Correction in the Lens tab in the Photo persona before hitting Develop? No, I didn't. I will try. Thanks. Link to post Share on other sites More sharing options...
