gesper Posted September 9, 2007 Share #1 Posted September 9, 2007 Advertisement (gone after registration) According to the manual, the yellow light is supposed to light while the battery is charging. On mine is flickers a little for maybe thirty seconds when I first start charging, but then goes out. Even so, the battery seems to be charging and shows a full charge after the prescribed three hours. Has anyone has seen this with their charger? I assume it is faulty wiring affecting only the LED itself and that the charger is functioning fine. Link to post Share on other sites More sharing options...
Advertisement Posted September 9, 2007 Posted September 9, 2007 Hi gesper, Take a look here Yellow light on battery charger. I'm sure you'll find what you were looking for!
wparsonsgisnet Posted September 9, 2007 Share #2 Posted September 9, 2007 G, I get a green lite when the charger is plugged in and a yellow lite while the battery is charging. The yellow goes out when the battery is fully charged. There is no blinking on my unit. If yours is new, it may be defective and a call to Leica might get you a new one. Link to post Share on other sites More sharing options...
egibaud Posted September 9, 2007 Share #3 Posted September 9, 2007 I had the same problem with a new battery, it was faulty and had it changed. Link to post Share on other sites More sharing options...
gesper Posted September 9, 2007 Author Share #4 Posted September 9, 2007 G, I get a green lite when the charger is plugged in and a yellow lite while the battery is charging. The yellow goes out when the battery is fully charged. There is no blinking on my unit. If yours is new, it may be defective and a call to Leica might get you a new one. It doesnt really blink, just flickers like a bad connection. I have had it since November. As long as it continues to charge, I can probably live with it. I have already bothered Leica US enough with other problems that I will hold off until it actually stops working. Link to post Share on other sites More sharing options...
fursan Posted September 9, 2007 Share #5 Posted September 9, 2007 same as Bill mentioned. G, I get a green lite when the charger is plugged in and a yellow lite while the battery is charging. The yellow goes out when the battery is fully charged. There is no blinking on my unit. If yours is new, it may be defective and a call to Leica might get you a new one. Link to post Share on other sites More sharing options...
ho_co Posted September 10, 2007 Share #6 Posted September 10, 2007 Weren't there reports of this kind of thing once before? If I recall correctly, Leica replaced the charger. This was at the beginning when they were still looking for the causes of SDS. Watch it carefully and smell it daily. --HC Link to post Share on other sites More sharing options...
jaapv Posted September 10, 2007 Share #7 Posted September 10, 2007 Advertisement (gone after registration) You may need to reset your battery by draining it completely. Pop it in the camera, deactivate autoshutoff and leave it on overnight. Link to post Share on other sites More sharing options...
gesper Posted September 11, 2007 Author Share #8 Posted September 11, 2007 Battery seems to be working fine. Only thing with a problem is the yellow light on the charger. Link to post Share on other sites More sharing options...
erl Posted September 11, 2007 Share #9 Posted September 11, 2007 I did have such a problem early on (Nov-Dec 2006). I tracked it down to the crappy power plug adapter not snapping into the charger properly. Another way to test it is try using the in car cirarette lighter option. That is independent of the plug adapter. If that work faultlessly, you can be fairly sure it comes back to the pug-in adapter. Link to post Share on other sites More sharing options...
