What framelines are visible when no lens is attached? Should be the 35/135mm pair. If not, the selector mechanism is stuck. You can try to get it working again by pushing the frameline selector lever.
If the framelines work ok without the lens attached and with other lenses the problem is with the lens bayonet or the position in which the lens is mounted. First make sure that you don't turn the lens past the locking position when mounting. Then check for any obvious fault with the slanting part of the lens bayonet.
