hirohhhh Posted February 13, 2022 Share #1 Posted February 13, 2022 Advertisement (gone after registration) I like one of my split ring straps I have, but I cannot attach it nicely to SL2. Is there any converter that I can use on the camera anchors to attach the split rings? Link to post Share on other sites More sharing options...
Advertisement Posted February 13, 2022 Posted February 13, 2022 Hi hirohhhh, Take a look here Split ring strap on SL. I'm sure you'll find what you were looking for!
helged Posted February 13, 2022 Share #2 Posted February 13, 2022 47 minutes ago, hirohhhh said: I like one of my split ring straps I have, but I cannot attach it nicely to SL2. Is there any converter that I can use on the camera anchors to attach the split rings? Not the most elegant solution, and needs a check now and then in case of tear, but the Peak Design (or similar) Anchor Links can be used. Link to post Share on other sites More sharing options...
hirohhhh Posted February 13, 2022 Author Share #3 Posted February 13, 2022 I was about to mention “other than Peak Design” in my first post because I felt someone is going to suggest that Yeah, that is an option but would be a bit wonky if the anchors are attached to the normal split ring. Link to post Share on other sites More sharing options...
