hirohhhh Posted February 8, 2022 Share #1 Posted February 8, 2022 Advertisement (gone after registration) I have Elmarit-R 28mm lens first version (1972). I just attached it for the first time on my M10-R using the original Leica R-Adapter M, and I see that the focusing rectangle doesn't work. Is this normal? How does one can focus without it, except trying to nail it using the meter on the focusing ring? Link to post Share on other sites More sharing options...
Advertisement Posted February 8, 2022 Posted February 8, 2022 Hi hirohhhh, Take a look here Focusing rectangle doesn't work R lens > M camera. I'm sure you'll find what you were looking for!
NigelG Posted February 8, 2022 Share #2 Posted February 8, 2022 (edited) I think you’ll find that it’s assumed you’re using LiveView on the rear screen or a Visoflex 020. There’s no mechanical rangefinder coupling on the adapter - it was introduced with the M240 to allow the use of R lenses with LiveView/EVF2 to make the M240 a “system” camera Edited February 8, 2022 by NigelG 1 1 Link to post Share on other sites More sharing options...
hirohhhh Posted February 8, 2022 Author Share #3 Posted February 8, 2022 Yeah, I can use rear screen with the focus peaking enabled, but it's not my preferred way of shooting with M cameras. Damn, I should've know this before I purchased the adapter Link to post Share on other sites More sharing options...
NigelG Posted February 8, 2022 Share #4 Posted February 8, 2022 Yes, more relevant IMHO in order to be able to use non M-style lenses like the R zooms or R “exotica” (in my case the R80 lux) unless you already had an R lens collection. I think there were threads at the time re the R adapter + CMOS LiveView in the M240 series being Leica’s sop to abandoned R users… In the end I sold mine (R adapter + R lens) due to the LV shutter lag + Evf2 issues on the M240P which didn’t really suit a portrait lens 🙄 It will be interesting to see if the M11 LV-metered sensor means R-adapted lenses become more usable as there will no longer be a shutter-lag penalty (just the “looking-at-a-tv-screen-instead-of-a-window one)? Link to post Share on other sites More sharing options...
hirohhhh Posted February 8, 2022 Author Share #5 Posted February 8, 2022 I was always hesitating buying a vintage lenses online, even thought I would always go for the character of the lens than the sharpness of the modern lenses. And the first time ever I decided to buy it and it doesn't work as expected You never know what you're getting if you combine modern tech with 50-60 years old. At least, my Leica expertise is not nearly on that level that I know the specs of every lens ever released. Link to post Share on other sites More sharing options...
pop Posted February 8, 2022 Share #6 Posted February 8, 2022 (edited) 2 hours ago, hirohhhh said: combine modern tech with 50-60 years old Nothing to do with technology age. As a matter of fact, the M technology is nearly 70 years old and based on the LTM technology which is close to a century, and R lenses are not usually called modern technology, either, not any more. It's simply the way any M camera works: that the rangefinder mechanism is driven by the lens, and that the lens must have the equipment to do so. On the other hand, M lenses lack the mechanism for the camera to open and close the aperture or diaphragm. Hence, you won't be able to use M lenses with cameras with automatic exposure when you expect it to choose the aperture value for you. So it's not about the 'specs of every lens ever released'; it's merely about how different types of cameras work. LTM cameras and M cameras have always worked that way. SLR cameras never did that. BTW, don't expect that you can use an M type lens on a Leica R camera, either, even though an adapter exists which lets you mount an M lens on an R camera. It won't do what you might expect. Edited February 8, 2022 by pop 1 Link to post Share on other sites More sharing options...
