I seem to have turned focus peaking off on my M11. I’d like to be able to turn it back on, or off. But while it was on, it is now off. I have Capture Assistants >Focus Aid set to Automatic. Where is the ‘on-off switch’ hiding?
x
I see it in the info profiles (within Capture Assistants), I use info profile 1 and in there you have a focus peaking option
Edited by Daedalus2000
1 hour ago, Photoworks said:
you can always turn it on and off with the confirmation center bottom of the 4 way navigator
This is how I have it setup...if you define the 4 options, you can use the center button to cycle thru views. Just be sure to define one with it off.
