There also have been lenses for Leica M39 screw-mount from other producers, which could be close-focused by a similar device as the new 35mm Apo-Summicron:
The Steinheil 1:2/50mm Quinon is coupled to the rangefinder down to a distance of approx. 1m.  Than you feel a light resistance and can go on focussing it down to 60cm. Though without coupling to the rangefinder the exact distance is difficult to fathom with a screwmount Leica - no problem of course for digital cameras with LiveView:
I have learned that older Nikkor lenses could be closed focussed in a similar way; though it may be difficult to find them with LTM-coupling (the Quinon is a rare bird as well).
Edited by UliWer
Several Japanese LTM lenses focus closer, but when you get closer than the camera's cam provides for, you have to focus by physically measuring the distance between the object and the film plane mark on the camera body (unless you have an EVF). In both cases, the focusing ring on the lens hesitates at the normal MFD, and a slight push beyond puts you into the close range. The two I have are a 50mm Nikkor H.C. f/2 and a 50mm Tanar H.C. f/3.5.
So it may be true then, Skyllaney in co op with Omnar lenses is rehousing Zeiss screw Mount lenses into custom M bodies, I asked if they could do the same refitted for a Barnack M39, they said it would be possible but it would have no rf coupling. I assumed that the 0.7m min focus of the 38mm 2.8 Sonnar I was looking at adapting would still work on a Barnack only without the use of the rf. Can any adapted lens with a closer minimum focusing distance be used, at that distance, with an uncoupled rangefinder?
