GulbadinNaib Posted November 14, 2021 Share #1 Posted November 14, 2021 Advertisement (gone after registration) Hi all, The Giottos SP8300 screen protector that came with the camera recently got a small chip on the edge that quickly evolved into a few hairline cracks across the glass. How can I safely remove it? I have read a few recommendations (heat it up with a hair dryer and pry it loose to remove it) but I don't feel comfortable about heating up the camera, and a few people said that removing the screen protector made the LCD screen also pop! Also it's already cracked and I suspect removal would be more difficult. Any experience with that? Would it be better to go to a camera repair (unless they charge $$$)? Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted November 14, 2021 Posted November 14, 2021 Hi GulbadinNaib, Take a look here Giottos LCD protector--safe removal??. I'm sure you'll find what you were looking for!
nf3996 Posted November 15, 2021 Share #2 Posted November 15, 2021 I have successfully removed old screen protectors with the use of a length of dental floss carefully looped under a corner of the protector and gently pulled from side to side under the protector. Some glue residue usually remains, but that can then be cleaned off afterwards. Alan 1 Link to post Share on other sites More sharing options...
GulbadinNaib Posted November 18, 2021 Author Share #3 Posted November 18, 2021 On 11/14/2021 at 4:22 PM, GulbadinNaib said: Hi all, The Giottos SP8300 screen protector that came with the camera recently got a small chip on the edge that quickly evolved into a few hairline cracks across the glass. How can I safely remove it? omegle xender I have read a few recommendations (heat it up with a hair dryer and pry it loose to remove it) but I don't feel comfortable about heating up the camera, and a few people said that removing the screen protector made the LCD screen also pop! Also it's already cracked and I suspect removal would be more difficult. Any experience with that? Would it be better to go to a camera repair (unless they charge $$$)? Thanks! thankyou Link to post Share on other sites More sharing options...
