deep_blue Posted November 2, 2021 Share #1 Posted November 2, 2021 (edited) Advertisement (gone after registration) I am experiencing a strange behaviour with my SL2-S and attached Atomos Ninja V recorder: If I set the camera to any 35mm resolution, it triggers the ninja when pressing the shutter as expected. If I change resolution to APS-C pressing the shutter does NOT trigger the ninja. Any hints welcome - thanks in advance! ### actual firmware is installed on SL2-S and Ninja ### Edited November 2, 2021 by deep_blue Link to post Share on other sites More sharing options...
Advertisement Posted November 2, 2021 Posted November 2, 2021 Hi deep_blue, Take a look here SL2-S and Atomos Ninja triggering bug?. I'm sure you'll find what you were looking for!
Slender Posted November 4, 2021 Share #2 Posted November 4, 2021 Weird.... doesnt do this on my SL2(not s). Which flag are you using in the atomos setting for triggering the recording? Trigger or Timecode? 1 Link to post Share on other sites More sharing options...
deep_blue Posted November 4, 2021 Author Share #3 Posted November 4, 2021 just checked it: both triggering settings only trigger the recorder when the camera ist set to any of the 35mm resolutions 1 Link to post Share on other sites More sharing options...
deep_blue Posted November 12, 2021 Author Share #4 Posted November 12, 2021 my SL2-S is on the way for a checkup by Leica customer care... The guys were not able to reproduce my problems and want to check the cam Link to post Share on other sites More sharing options...
Marckyokay Posted April 23, 2022 Share #5 Posted April 23, 2022 On 11/12/2021 at 10:28 PM, deep_blue said: my SL2-S is on the way for a checkup by Leica customer care... The guys were not able to reproduce my problems and want to check the cam Long long ago.... but how did this story end for you? Link to post Share on other sites More sharing options...
deep_blue Posted June 18, 2022 Author Share #6 Posted June 18, 2022 uuups - sorry, I have not been notified about your answer. After checking everything and doingt some more experiments I found, that the camera triggers the ninja with every Movie/Compression setting only,. if there are NO SD-cards inserted in the camera. Once you have SD-cards in the cam, it only triggers the ninja with some but not all settings. Whatever sense this makes... Link to post Share on other sites More sharing options...
Photoworks Posted June 18, 2022 Share #7 Posted June 18, 2022 Advertisement (gone after registration) I AM USING THE atomos shinobi 7 monitor with the SL2 One option missing in this setup is the record frame line on the monitor. most of the time I can only look at one monitor when holding and filming at the same time. there is no visual signal on the monitor that I am recording on the camera. looking down on the monitor on top of hot-shoe I can't even see the camera back screen. The only feedback is a gray dot on the OLED top screen.. Link to post Share on other sites More sharing options...
Kristofferpaulsen Posted February 4 Share #8 Posted February 4 oh my god so i was on a job almost a year ago and this started happening, so we shot to card and had to deal with the crop.. I kept meaning to investigate, and FINALLY got it out again today.. and googled.. and yes. There was a goddamned SD card in the camera. Took it out and it worked fine. Why am i like this? Link to post Share on other sites More sharing options...
