Case68 Posted September 17, 2021 Share #1 Posted September 17, 2021 Advertisement (gone after registration) I've had my q2 around a year, and I"m playing for the first time with Leica Fotos and Nikon SB700 flash. With the SB700 on manual, manually triggering the camera works fine, including the flash. But when I trigger from the Iphone via Fotos, the flash doesn't go off, though the camera still takes a pic. I've tried changing various settings with no luck. Will Fotos simply not trigger a non-Leica flash, or is there some trick I'm missing here? Thanks for any help. Link to post Share on other sites More sharing options...
Advertisement Posted September 17, 2021 Posted September 17, 2021 Hi Case68, Take a look here Leica Fotos won't trigger flash . I'm sure you'll find what you were looking for!
AlexKirk Posted September 17, 2021 Share #2 Posted September 17, 2021 48 minutes ago, Case68 said: Will Fotos simply not trigger a non-Leica flash, or is there some trick I'm missing here? I have tried to reproduce this with my camera. Flash works for me with Leica Photo remote control on iPhone. What flash unit do you use ? Link to post Share on other sites More sharing options...
Case68 Posted September 17, 2021 Author Share #3 Posted September 17, 2021 (edited) 1 hour ago, AlexKirk said: I have tried to reproduce this with my camera. Flash works for me with Leica Photo remote control on iPhone. What flash unit do you use ? Nikon SB700. I've connected and reconnected and turned off and on. Inconsistently the flash will trigger from the phone, but then seems to freeze. Edited September 17, 2021 by Case68 Link to post Share on other sites More sharing options...
Case68 Posted September 18, 2021 Author Share #4 Posted September 18, 2021 Follow-up. I tried the same set-up with a Nikon SB600, and it works fine. So apparently the original problem was just some specific conflict between Fotos and the 700. Link to post Share on other sites More sharing options...
