dkCambridgeshire Posted August 25, 2021 Share #1  Posted August 25, 2021 Advertisement (gone after registration) My SL 601's, BC-SCL4 charger suddenly ceased working and because it's a sealed unit I cannot determine the cause of its failure ... checked the obvious possibilities eg power cable and terminals. Managed to source a s/h unit which arrives tomorrow but meantime a forum member suggested replacing with a Nitecore unit  https://www.nitecore.co.uk/Shop/Products/Chargers/13657-Nitecore-ULSL-Leica-Camera-Charger.html#Description. ... I should have ordered a new Nitecore instead of the s/h Leica unit. Nitecore has been mentioned on the forum previously ... might be of interest to anyone else seeking a replacement charger. A new Leica BC-SCL4 costs  £130 ... Nitecore is just £67.95 ... charger compatible with SL601, SL2 and Q2 batteries. dunk Link to post Share on other sites More sharing options...
Advertisement Posted August 25, 2021 Posted August 25, 2021 Hi dkCambridgeshire, Take a look here SL 601 battery charger failed. I'm sure you'll find what you were looking for!
frame-it Posted August 25, 2021 Share #2  Posted August 25, 2021 9 minutes ago, dkCambridgeshire said: My SL 601's, BC-SCL4 charger suddenly ceased working and because it's a sealed unit I cannot determine the cause of its failure ... checked the obvious possibilities eg power cable and terminals. Managed to source a s/h unit which arrives tomorrow but meantime a forum member suggested replacing with a Nitecore unit  https://www.nitecore.co.uk/Shop/Products/Chargers/13657-Nitecore-ULSL-Leica-Camera-Charger.html#Description. ... I should have ordered a new Nitecore instead of the s/h Leica unit. Nitecore has been mentioned on the forum previously ... might be of interest to anyone else seeking a replacement charger. A new Leica BC-SCL4 costs  £130 ... Nitecore is just £67.95 ... charger compatible with SL601, SL2 and Q2 batteries. dunk with the nitecore, just make sure the incoming supply is high enough.. i.e dont plug it into a laptop or something like that 1 Link to post Share on other sites More sharing options...
beewee Posted August 26, 2021 Share #3  Posted August 26, 2021 If you have a voltage or multi-meter you can measure across the + and - contacts of the battery. If voltage is below 3v then it’s probably toast. Link to post Share on other sites More sharing options...
dkCambridgeshire Posted August 26, 2021 Author Share #4  Posted August 26, 2021 ^^ already tested with multi-meter and no output current from the charger. Replacement s/h charger arrived today from Ffordes and batteries recharged. Link to post Share on other sites More sharing options...
