Pelu2010 Posted August 22, 2021 Share #1  Posted August 22, 2021 Advertisement (gone after registration) Hey ,  how can I flash with the camera set to electronic shutter? And would that help with HSS sync . thanxs peter Link to post Share on other sites More sharing options...
Advertisement Posted August 22, 2021 Posted August 22, 2021 Hi Pelu2010, Take a look here Flash with electronic shutter?. I'm sure you'll find what you were looking for!
buj Posted August 22, 2021 Share #2 Â Posted August 22, 2021 i think there is no way using electronic shutter with flash Link to post Share on other sites More sharing options...
Stuart Richardson Posted August 22, 2021 Share #3 Â Posted August 22, 2021 The problem is that flash duration is typically quicker than the scan speed of the sensor readout. The flash is over before the camera is done pulling the image off the sensor so you only illuminate part of the image. HSS might work, if it pulses long enough, but I am not sure. Some powerful studio flashes might be slow enough at full power, but they would probably be too bright. The other way around is to use a camera with a global shutter. None of these things is easy or practical at this point I think. What is your goal in using an electronic shutter with flash? If it is about avoiding camera vibration, flash is usually fast enough to make that not an issue. Link to post Share on other sites More sharing options...
jankap Posted August 22, 2021 Share #4 Â Posted August 22, 2021 (edited) Perhaps with a sensor with a global shutter, future! Edited August 22, 2021 by jankap Link to post Share on other sites More sharing options...
