NJUSA1 Posted July 12, 2021 Share #1 Posted July 12, 2021 Advertisement (gone after registration) If I select the self-timer in the main menu for say 8 seconds delay, does it wait for the shutter button to be depressed? Can it be done remotely? Thanks from an old school photographer 😉 Link to post Share on other sites More sharing options...
Advertisement Posted July 12, 2021 Posted July 12, 2021 Hi NJUSA1, Take a look here Q2 Monochrom SELF-TIMER question. I'm sure you'll find what you were looking for!
ianforber Posted July 12, 2021 Share #2 Posted July 12, 2021 I have the Q2 rather than the Q2M but am naively assuming it will be the same! The self timer can be set for either 2 seconds or 12 seconds. It can be started by pressing the shutter button. The only way to trigger the shutter remotely is to use the Leica Fotos app on your smartphone. Many people here have problems getting Fotos to connect with their camera but personally it works fine for me, but I only use it as a remote control for the camera and not to transfer images to my iPhone or iPad. Hope this helps. Link to post Share on other sites More sharing options...
scroy Posted July 15, 2021 Share #3 Posted July 15, 2021 The only way I've found to remotely control the shutter is the Fotos App. If you need an arbitrary delay using the shutter button, there is a trick - use the interval shooting feature for a single shot set the arbitrary time based on the delay setting. Josh Lehrer [Leicastore Miami] mentioned the feature during one of the YouTube sessions. 1 Link to post Share on other sites More sharing options...
NJUSA1 Posted July 23, 2021 Author Share #4 Posted July 23, 2021 On 7/12/2021 at 5:20 PM, ianforber said: I have the Q2 rather than the Q2M but am naively assuming it will be the same! The self timer can be set for either 2 seconds or 12 seconds. It can be started by pressing the shutter button. The only way to trigger the shutter remotely is to use the Leica Fotos app on your smartphone. Many people here have problems getting Fotos to connect with their camera but personally it works fine for me, but I only use it as a remote control for the camera and not to transfer images to my iPhone or iPad. Hope this helps. Thanks I’ll try the Leica Fotos app. Even if I set the self timer to say 12 seconds, it will still require the initial pressing of the shutter button which could cause some minimal blur. Link to post Share on other sites More sharing options...
NJUSA1 Posted July 23, 2021 Author Share #5 Posted July 23, 2021 On 7/15/2021 at 7:25 AM, scroy said: The only way I've found to remotely control the shutter is the Fotos App. If you need an arbitrary delay using the shutter button, there is a trick - use the interval shooting feature for a single shot set the arbitrary time based on the delay setting. Josh Lehrer [Leicastore Miami] mentioned the feature during one of the YouTube sessions. Thanks for the tip. I purchased my Q2M from Josh so I’ll give him a call. Link to post Share on other sites More sharing options...
