Richard K Posted July 9, 2021 Share #1 Posted July 9, 2021 Advertisement (gone after registration) Those of you that use a Q2 monochrom, what do you do to be able to accommodate say a red filter? The original hood is not the best if you are going to use filters. What solution have you come up with? I ask because you can’t darken a blue sky by moving the blue slider to the left, right? Link to post Share on other sites More sharing options...
Advertisement Posted July 9, 2021 Posted July 9, 2021 Hi Richard K, Take a look here Q2 Hood and Filter Considerations . I'm sure you'll find what you were looking for!
Leica28 Posted July 9, 2021 Share #2 Posted July 9, 2021 The solution is to not use the lens hood at all. I never found it useful in the field. When I had a Q2M, I kept a yellow filter on constantly when outdoors. It darkened skies quite nicely. Orange and red filters deepen the effect. A polarizer worked well, too. Regardless, you can use a yellow, red, or orange filter on your camera with the lens hood attached. No problem because the filters do not rotate. Link to post Share on other sites More sharing options...
hdmesa Posted July 12, 2021 Share #3 Posted July 12, 2021 The hood is great for using a filter, but not so much for having to change them out. When I had the Q2M, I put on a light red filter and left it there all the time with the hood over it. There is so little penalty for raising ISO, I even used the light red filter indoor in dim lighting (where it still works nicely to lighten certain skin tones). If I knew in advance I was going to need to be switching between color filters or between a color filter and a protective filter, I would leave the hood off and attach the protective ring. I kept one of the Leica black pouches in my camera bag to hold either the hood or the protective ring when not in use. Link to post Share on other sites More sharing options...
