Full moon and question!
carylwithay
Caryl: Trouble is, you can't get a lens with a greater length than 135mm for the M. Only way to go longer is via the Visoflex - a Leica device (no longer made) that turns the M into a reflex camera; it's rather like coupling a 19th century steam locomotive to a Japanese bullet train, but it does work (I use one on my M7). That then means you can use Leica lenses up to 400mm (designated Telyt), or even more. It's all slightly clunky by modern standards, and a bit squinty in operation, but reasonable pricewise since they're all secondhand - I picked up a near-mint boxed Visoflex III plus 280mm Telyt for 299GBP a year ago. You'd either find it great fun, or a right PITA. Other more experienced members might have further advice!
cheers:
Sam
"If all that would work on the M* and no damage it, I could be tempted."
...well it can, apparently...there was an article in LFI magazine Issue 5/2007 (June/July) where the use of a Visoflex on the M8 was covered...worth tracking down if you're interested.
cheers:
Sam
Can an M be hooked up to a Leica Spotting Scope, with an adapter, like my D-lux 3 was for this moon photograph ? Then you would have a nice little spotting scope around the house to enjoy....Al
Two casual moon photos with M8 and:
APO-Telyt 3.4/135mm
[ATTACH]51785[/ATTACH]
Visoflex III and Telyt 4.8/280
[ATTACH]51786[/ATTACH]
Both 100% crops.
Apart from rather strong thermic air currents in the second image you can easily tell that the APO-Telyt is a far, far better lens. Attaching the M8 to a spotting scope or, better still, a telescope, will yield much better results.
Thank you, Sam. If all that would work on the M* and no damage it, I could be tempted. I love to push the medium. However, the M8 does not take to all lenses well.
Caryl
providing you are careful mounting the M8, the Viso III will cause no damage
it was designed to give the M series cameras DSLR capabilities, meaning allowing for through the lens focus so tele and macro work can be done
these have not been made for decades but some are available on the used market, though prices have escalated of late
the adapters & lenses for it make for arcane study, but the results with it can be excellent
remarkably long lenses are far cheaper than I would have expected ...once the skies get clear here at night (we have had beaucoups rain on the Gulf Coast) I will try the moon with my 560 Telyt just for yucks
