This weekend I was out shooting with my M10-M. For the duration of the day I had my ISO ring on Auto. My Aperture ring on F8 and my shutter speed at 1/500.
when I reviewed my images I was expecting them to have different ISO setting but a fixed shutter and Aperture. However, I had a fixed shutter speed (which was fine) but then I had different aperture and ISO settings.
what am I doing wrong?
thanks for your help
Vincent
x
It's normal. Also if you shoot fully in manual, your f/stop (aperture) often is different from the one you used. It's a guesstimate. In the M-mount, there is no linkage that transmits the aperture data from the lens to the body. This happens also in 6-bit coded lenses. You can shoot all day long at f/16 (to say one), and then you find out that your exif tell you f/13, f/19, f/22.
Forget about this, it's irrelevant for you to make great imagery.
Welcome to the forum.
Vincent
Welcome to the Forum.
See also this Tread.
Hi Vincent,
Although the M10M can handle high ISO fairly well the lower the ISO the cleaner the file will be.  So unless you were constantly shooting fast moving objects I would also set the speed dial to Auto and two times the focal length to ensure no camera shake, the Auto ISO to a max of 6400 ISO for example.   With the aperture ring you select the depth of field and Auto speed and Auto ISO will - within their set limits - automatically be selected to the lowest possible value combination.
For more static scenes it makes no sense to set the speed fixed to 1/500 and let the Auto ISO compensate accordingly.  Although the M10M has a very good ISO performance, a ISO 200 file will always show less noice than a ISO 800 file. While a shot taken at 1/125 with a normal or wide lens will be no different than the shot taken at 1/500.
Again this technique does not apply for fast moving subject.
