Hi I have a Sl2s and been using a remote lead to fire Camera.and all ok .But when connected to my Drop art control box the Camera will not fire the shutter .all that happens is the rear scream flashes.so I get the opinion that this unit is not compatible with the Leica.but cable connection is same as my hand remote that works 🤔And this unit works with cano and Nikon without a problem.any suggestions thanks Paul
Hi! As far as I understand (and based on my experience), SL2/SL2-S follows the Panasonic protocols (4-pole plug), so whatever works for Panasonic Lumix S1/S1R/S1H/S5 should also work with Leica SL2/SL2-S. Note, however, that Leica uses a 3.5mm plug whereas the Panasonic a 2.5mm plug, so you may need a 2.5mm-to-3.5mm plug adapter. Some 2-pole plugs also works on SL2/SL2-S.
Does anyone have any experience with Alpine Labs Spark with an SL2/SL2-s? I previously used their Pulse remote with a Nikon D800 and it was very good.
Thanks in advance!
Regards
Colin
Thanks in advance!
Regards
Colin
Possibly. Panasonic S1 is listed as compatible. The Alpine Labs Spark site states that S1 uses a 3-pole plug which is incorrect; the S1 uses a 4-pole plug (as S1R). Contact Alpine Labs Spark to check the S1-compatibility. Or, use MIOPS as shown in my previous post, it works with Leica SL2/SL2-S with a 2.5mm to 3.5mm plug adapter. I use the latter on SL2-bodies, as well as for Leica S-bodies.
  • 4 months later...
Hi I still can get my sl2s to work with my drop art splash kit it will not fire the shutter ,but I can fire shutter with a cheap cable remote.I have tried 2 pole fron unit to 4 pole in camera nothing ,but my Nikon works what ever pole cable I use .frustrating any ideas thanks again paul
Thanks in advance!
Regards
Colin
It looks like the Panasonic S1 is not compatible with Spark.
  • 1 year later...
I know this topic is old but to help others, I found a shop where you can buy this cable.
They will also send international.
You can find it here: https://blackforestmotion.com/en/produkt/shutter-release-cable/
You need to select Leica - SL2 and you will get a 2,5mm (3pin) to 3,5mm (4pin) cable which is the same as the Panasonic L1, only with 3,5mm instead of 2,5mm.
So perfect for the Leica SL2 and other cameras with the 3,5mm connector.
I tested it with the LRTimelapse Pro Timer and the Leica SL2.
