I have a Leica SL system, currently I can’t use the Wifi connection from my camera to phone. Whenever I try to turn on the Wifi on my camera or am in system info, my camera will freeze. I had to unplug the battery and restart the camera for this issue to go away, every time.
I have try to reset the camera, removing SD....  still have the issue , Any Idea?
Charlie
On 4/26/2021 at 4:57 PM, jaapv said:
First both  reset the camera to factory settings (after saving your profiles) and clear the network list on your phone. Does the problem persist?
Hey Jaap,
thanks for your help, I have try both, still have that problem.
21 minutes ago, leicameech said:
Is your firmware the latest version? 3.7?
thanks for the reply.
On the issue of freezing Im not able to check system version, but I'm pretty sure that camera running the newest version of firmware.
  • 1 year later...
Any resolution to this issue? I have the same thing that started to happen of late. I haven’t used the wifi before and I tried it recently and it just freezes up until the battery is removed. The. it goes back to normal. Until I try wifi again. Has anyone had anything similar happen and managed to find a solution? Thanks
Ă—
Ă—
