Guest Posted April 21, 2021 Share #1 Posted April 21, 2021 (edited) Advertisement (gone after registration) Hi everyone! It may seem a stupid question, but I still want to make sure that an aggressive shadows recovery (even at low ISOs) in Lightroom (or any other similar software) may introduce quite dramatic luminance noise (see the pic generated from the raw file), if the shot was taken under certain lighting conditions. Is this normal for digital sensors? The noise in picture has been generated by the Leica Q2 Monochrom sensor (after processing it in LR, with shadows drastically recovered). Thank you! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited April 21, 2021 by Guest Add more info Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/320146-luminance-noise-in-shadows/?do=findComment&comment=4185685'>More sharing options...
Advertisement Posted April 21, 2021 Posted April 21, 2021 Hi Guest, Take a look here Luminance noise in shadows . I'm sure you'll find what you were looking for!
jaapv Posted April 21, 2021 Share #2 Posted April 21, 2021 Yes, of course. That is quite normal, this is actually a rather good result. If you want to get rid of it use Topaz Denoise AI or the new DXO Pure Raw. 1 Link to post Share on other sites More sharing options...
markhout Posted April 21, 2021 Share #3 Posted April 21, 2021 All agreed, but I don't see dramatic lighting conditions in this image (like high contrasts). It looks simply underexposed and I would indeed expect this behavior of any sensor, modern or older. I don't believe that the possibility to crank up the ISO immediately leads to super high dynamic range. Even the high DR of the Q2 monochrom has its limitations. 1 Link to post Share on other sites More sharing options...
jaapv Posted April 21, 2021 Share #4 Posted April 21, 2021 3 hours ago, markhout said: crank up the ISO immediately leads to super high dynamic range Actually, quite the opposite. Link to post Share on other sites More sharing options...
RoySmith Posted April 22, 2021 Share #5 Posted April 22, 2021 jaapv is correct as usual. Photons to photos has a nice chart illustrating the reduction in dynamic range with increasing iso with the Q2. Link to post Share on other sites More sharing options...
Guest Posted April 26, 2021 Share #6 Posted April 26, 2021 On 4/21/2021 at 9:13 PM, jaapv said: Yes, of course. That is quite normal, this is actually a rather good result. If you want to get rid of it use Topaz Denoise AI or the new DXO Pure Raw. Thanks a ton, Jaap for reassurance. I also thought it was pretty standard behaviour for digital sensors when they try to amplify the signal super-dark shadow areas, or smth. along these lines. Cheers! Link to post Share on other sites More sharing options...
Guest Posted April 26, 2021 Share #7 Posted April 26, 2021 (edited) Advertisement (gone after registration) On 4/21/2021 at 11:01 PM, markhout said: All agreed, but I don't see dramatic lighting conditions in this image (like high contrasts). It looks simply underexposed and I would indeed expect this behavior of any sensor, modern or older. I don't believe that the possibility to crank up the ISO immediately leads to super high dynamic range. Even the high DR of the Q2 monochrom has its limitations. Thanks, Mark. Yes, it is indeed underexposed (even ultra-underexposed). I did it intentionally to see what the sensor is capable of when pulling up the shadows later in post. Cheers! Edited April 26, 2021 by Guest Add more info. Link to post Share on other sites More sharing options...
Guest Posted April 26, 2021 Share #8 Posted April 26, 2021 On 4/22/2021 at 4:47 PM, RoySmith said: jaapv is correct as usual. Photons to photos has a nice chart illustrating the reduction in dynamic range with increasing iso with the Q2. Thanks a lot, Roy! Link to post Share on other sites More sharing options...
