Expensive conversions of R lenses to RF coupled M - why bother when there is an equivalent M lens?
Recently I have seen a number of permanently M mount converted R lenses on the market. Some of these are RF coupled and some are not. There is a 50 Summilux-R/II on Facebook marketplace at the moment for a mere £3,000. I really cannot understand why anyone would buy this, when for around two thirds of that price, they could buy the far smaller 50 Summilux III e46 M lens, which has pretty similar optical performance to the series two Summilux R. I only paid around £1600 for one of the quite rare L39 mount versions of the e46 S-III lenses, in mint condition and it is my 50mm lens of choice on both film and digital M cameras. I recognise that prices for this lens have climbed over the two years since I bought it. The R version of the 50 Summilux with its conversion mount, is a pretty big lump to have on the front of your M camera. I know as I have been using the 21-35 R lens on my M10-R for the last few days and it is not a particularly well balanced combination.
Can anyone else understand why one would put a lot of work and money into converting an R lens, where there is a readily available, equal performance purpose designed M lens, at a considerably lower price point. Fair enough converting lenses like the various R zoom and telephoto lenses, where there is no M equivalent and I do use as I mentioned, the 21-35 and also the 80-200 on M cameras with live view for non-RF focusing. However, this is just with the R to M adapter and not a permanent modification, as I still use them on my R bodies for film and with the R to L adapter on my SL601.
Wilson
Edited by wlaidlaw
  • 3 weeks later...
I think it's done mostly for the bragging rights. "Look what I have here!"  Now if someone would make an adapter that retains the rangefinder focusing with R lenses that would be something.
PF
If you want to use the R-lenses on a digital body it makes much more sense to by an SL2, SL2-S, or the original SL (cheap now) plus the R-Adapter L. R-lenses are very nice on an SL body.
You can do things just as well on a digital M with an EVF and an R Adapter M,  as with the original SL. With IBIS though, the SL2 is another matter.
It is now possible to get a variety of lenses 'converted' to M mount with RF coupling. I see no problem with doing this as it gives a lens new life. The cost of doing so can be high though and so it may exceed the cost of a similarly specified alternative. This is up to the buyer or owner of the lens is it not?
Paul,
Of course it is up to the owner of the lens and no doubt one could get a Pratika or Chinon lens expensively converted to RF coupled. My point was: Does it make sense to do this, especially with R lenses, when there is not infrequently already an optical analogue in M mount like the example I quoted with the 50 Summilux R-II and the 50 Summilux M-III. The M lens is much smaller than the converted lens, will slightly out-perform its retrofocal equivalent and will be cheaper into the bargain. I was not arguing against the use of non-RF lenses with adapters, which I often do myself on live view M cameras.
Wilson
Financially it doesn't! But there can be other reasons for such conversions. I'm contemplating an RF coupled mount for a 42mm Summer at the moment. The cost will far exceed the cost/value of the Summar, but I will then have a copy of one of Barnack's lenses, as used in one of his prototypes, which is usable on an M body. I'd struggle to see the logic in an expensive R conversion myself but some may have specific reasons for wanting a lens to remain in use on an M. I suspect that not everything comes down to the absolute value/cost/worth in such cases. All that said, an SL or other mirrorless is an easier and cheaper way to go for sure!
A universal M mount which can be relatively easily adapted to specific focal length lenses is not beyond the bounds of possibility - it would require spacers/adapters for each lens together with profiled cams which could be fitted for absolute focal lengths - but would require sufficient demand which might be the sticking point.
Paul,
Effectively I have such an adapter/focusing mount for Contax RF lenses with coupling to an M mount camera, made by Amedeo Muscelli. Obviously the prerequisite is that the flange focal distance of the lens you want to make RF coupled must have a flange focal distance of greater than 27.80mm, to allow for the adapter. I am not a great fan of this adapter as it focuses the "wrong/Contax way round" compared with Leica. I believe his latest adapters focus in the "correct' rotation direction.
Wilson
