helged Posted March 14, 2021 Share #1 Posted March 14, 2021 Advertisement (gone after registration) Hello! I am pondering on a project with Lumix S1R or S5, with * 21mm or wider focal length, with * good corner sharpness (stoppe down a little), and with * a lens that is not particularly prone to flare. For this project, expensive lenses like SL16-35 are out of question. The lens could be fully manual. I have the Voigtlander 15mm Super-Heliar III. This lens is fine on M and SL, but it shows some edge/corner smearing on S1R/S5. Any suggestions? Is Sigma 20-60mm (@20mm) an alternative? Link to post Share on other sites More sharing options...
Advertisement Posted March 14, 2021 Posted March 14, 2021 Hi helged, Take a look here Wide angle for Lumix S. I'm sure you'll find what you were looking for!
jdlaing Posted March 14, 2021 Share #2 Posted March 14, 2021 2 hours ago, helged said: Hello! I am pondering on a project with Lumix S1R or S5, with * 21mm or wider focal length, with * good corner sharpness (stoppe down a little), and with * a lens that is not particularly prone to flare. For this project, expensive lenses like SL16-35 are out of question. The lens could be fully manual. I have the Voigtlander 15mm Super-Heliar III. This lens is fine on M and SL, but it shows some edge/corner smearing on S1R/S5. Any suggestions? Is Sigma 20-60mm (@20mm) an alternative? The 20-60 is a very good alternative. I also have a Konica Hexanon Dual 21-35 that I haven’t had a chance to try on a Lumix S1R yet but will shortly. 1 Link to post Share on other sites More sharing options...
BernardC Posted March 15, 2021 Share #3 Posted March 15, 2021 You may want to look at the Laowa wides. They have two 15mm L-Mount lenses, and a 10-18mm zoom. I have the 15/2.0, and it's very good. The major issue is that it focuses the wrong way (Nikon direction, not Leica direction), which I find extremely annoying. I mostly use it in "super 35" crop mode for video, but it holds-up in the corners in full-frame mode. The Panasonic 16-35 is also supposed to be excellent. A little more expensive, but I'm sure there are deals to be found. 2 Link to post Share on other sites More sharing options...
helged Posted March 15, 2021 Author Share #4 Posted March 15, 2021 19 hours ago, jdlaing said: The 20-60 is a very good alternative. I also have a Konica Hexanon Dual 21-35 that I haven’t had a chance to try on a Lumix S1R yet but will shortly. 5 hours ago, BernardC said: You may want to look at the Laowa wides. They have two 15mm L-Mount lenses, and a 10-18mm zoom. I have the 15/2.0, and it's very good. The major issue is that it focuses the wrong way (Nikon direction, not Leica direction), which I find extremely annoying. I mostly use it in "super 35" crop mode for video, but it holds-up in the corners in full-frame mode. The Panasonic 16-35 is also supposed to be excellent. A little more expensive, but I'm sure there are deals to be found. Thanks! I did test the 21 Super-Elmar-M on the S5 (with the Leica adapter) today; the edges were a little soft up to and including f5.6, but had a fine sharpness at f8 and f11 (with diffraction kicking in at about f13). Link to post Share on other sites More sharing options...
michali Posted March 16, 2021 Share #5 Posted March 16, 2021 On 3/15/2021 at 9:18 PM, helged said: Thanks! I did test the 21 Super-Elmar-M on the S5 (with the Leica adapter) today; the edges were a little soft up to and including f5.6, but had a fine sharpness at f8 and f11 (with diffraction kicking in at about f13). Helge have you tried the Sigma 14-24mm f2.8? It's very good. Link to post Share on other sites More sharing options...
helged Posted March 16, 2021 Author Share #6 Posted March 16, 2021 1 minute ago, michali said: Helge have you tried the Sigma 14-24mm f2.8? It's very good. Thanks - it's on my to-consider-list... I even think a little about substituting the SL16-35 with the Sigma 14-24. Not that I don't like the SL16-35 (it's brilliant!), but it will 'free' some money, for instance for one of the wide SL Crons coming in 2021/22. 1 Link to post Share on other sites More sharing options...
Marc Tenner Posted March 16, 2021 Share #7 Posted March 16, 2021 Advertisement (gone after registration) I would guess the Voigtländer 21 1.4 is what you are searching for. Lightroom offers a lens profile to compensate its only „weakness“: vignetting. 1 1 Link to post Share on other sites More sharing options...
jdlaing Posted March 18, 2021 Share #8 Posted March 18, 2021 LUMIX S1R & Konica Hexanon Dual 21-35mm @21mm. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/318929-wide-angle-for-lumix-s/?do=findComment&comment=4163316'>More sharing options...
Ivar B Posted March 19, 2021 Share #9 Posted March 19, 2021 What about the Pana 16-35? An excellent lens which should meet your requirements very well. 2 Link to post Share on other sites More sharing options...
helged Posted March 20, 2021 Author Share #10 Posted March 20, 2021 21 hours ago, Ivar B said: What about the Pana 16-35? An excellent lens which should meet your requirements very well. Hei @Ivar B! Yes, this is another lens to consider... Many options out there (which is good, but also somewhat 'complicated'). Link to post Share on other sites More sharing options...
