Pixeleater Posted March 12, 2021 Share #1 Posted March 12, 2021 Advertisement (gone after registration) Which has more contrast? Sharp corner to corner? I'll use it on an M10-R for architectural, environmental, and landscape. Not always wide open. Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted March 12, 2021 Posted March 12, 2021 Hi Pixeleater, Take a look here 28mm Summicron or 28mm Elmarit Question. I'm sure you'll find what you were looking for!
a.noctilux Posted March 12, 2021 Share #2 Posted March 12, 2021 I use the two M lenses, one of this 2/28mm and this 2.8/28mm Closed down a bit to f/4 or f/5.6/8, I hardly see any one "better contrast" than the other. I hardly use for corner to corner sharpness, so we can differ here. Simple answer is as simple as each one can give good result at same apertures. Link to post Share on other sites More sharing options...
sebben Posted March 12, 2021 Share #3 Posted March 12, 2021 According to the MTFs the Summicron is better in the corners. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Summicron at the bottom, you can get the full data sheets on the Leica website Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Summicron at the bottom, you can get the full data sheets on the Leica website ' data-webShareUrl='https://www.l-camera-forum.com/topic/318839-28mm-summicron-or-28mm-elmarit-question/?do=findComment&comment=4159208'>More sharing options...
Pixeleater Posted March 12, 2021 Author Share #4 Posted March 12, 2021 Thanks! Link to post Share on other sites More sharing options...
stephan54 Posted March 12, 2021 Share #5 Posted March 12, 2021 (edited) I started with an Elmarit 28asph and was very satisfied with the detail and colour. Switched to the Summicron 28 v2 recently as I preferred the colour rendering. Both lenses are equally sharp according to me, but the Summicron makes the separation between the colours a bit more gradual. In addition the colour rendering of the Summicron was much the same as my Summilux 50asph. You cannot go wrong with either lens. Edited March 12, 2021 by stephan54 1 Link to post Share on other sites More sharing options...
Pixeleater Posted March 12, 2021 Author Share #6 Posted March 12, 2021 Stephan54, is the Summicron 28 v2 lens hood plastic or metal? Can't tell from the product page. Thanks. Link to post Share on other sites More sharing options...
lawman Posted March 12, 2021 Share #7 Posted March 12, 2021 Advertisement (gone after registration) 4 hours ago, Pixeleater said: Stephan54, is the Summicron 28 v2 lens hood plastic or metal? Can't tell from the product page. Thanks. The new Summicron (v2) is a metal screw on lens hood. I have both of these lenses and find that although the Elmarit is a great lens (and very sharp) it is a little on the contrasty side for me and therefore I prefer the Summicron. As mentioned, once stopped down a bit, both lenses are very sharp, although I have not done a corner comparison. Hope this helps, Larry 1 Link to post Share on other sites More sharing options...
astrostl Posted March 13, 2021 Share #8 Posted March 13, 2021 If architectural is your first subject, worth noting that the Elmarit has less distortion than the Summicron (while both are low). Especially if shooting stopped down, I would default to the Elmarit. 1 Link to post Share on other sites More sharing options...
Herr Barnack Posted March 13, 2021 Share #9 Posted March 13, 2021 (edited) I had the 28 Summicron v.1 (#11604), currently have the 28 Elmarit #11677. The main reason to choose the Summicron IMO would be to have the f/2.0 maximum aperture. My copy of the Summicron had truly outstanding velvety color rendition & saturation at f/2 and was bitingly sharp at middle apertures and beyond.. The Elmarit is a solid performer and is right on the heels of the Summicron when stopped down to the middle apertures. This may or may not be a consideration, but the minimum aperture on the Elmarit is f/22 while it is f/16 on the Summicron; something to think about for landscape and street photography where hyperfocal depth of field is a factor. If you shoot stopped down the majority of the time, the Elmarit will serve you well. if you are into low light shooting and shooting wide open, the Summicron will serve you well. I tend to think of the Elmarit as the all-around 28, the Summicron as the middle way and the Summilux as the holy grail 28. YMMV. Edited March 13, 2021 by Herr Barnack 1 Link to post Share on other sites More sharing options...
Cobram Posted March 15, 2021 Share #10 Posted March 15, 2021 Landscape --> Elmarit ASPH People shots --> Summicron ASPH The only thing I don't like about my Cron 28 is rendering at infinity. Again rendering, not sharpness. Otherwise it is my most used lens by far. Link to post Share on other sites More sharing options...
Casey Jefferson Posted March 15, 2021 Share #11 Posted March 15, 2021 51 minutes ago, Cobram said: Landscape --> Elmarit ASPH People shots --> Summicron ASPH The only thing I don't like about my Cron 28 is rendering at infinity. Again rendering, not sharpness. Otherwise it is my most used lens by far. I've just gotten the 28/2, V1 to be specific, a few days with the lens concluded that it rendered better than my 35/2 ASPH V1 (which I was pretty happy with). The 28/2 seem to have more rounded tonal transition while retaining the clarity at smaller aperture which the 35 looked a little harsher (or flatter, hard to describe) in comparison. But I've seen pictures that matches your description prior to purchasing this lens... Link to post Share on other sites More sharing options...
Pixeleater Posted March 16, 2021 Author Share #12 Posted March 16, 2021 (edited) On 3/15/2021 at 2:02 AM, Cobram said: Landscape --> Elmarit ASPH People shots --> Summicron ASPH The only thing I don't like about my Cron 28 is rendering at infinity. Again rendering, not sharpness. Otherwise it is my most used lens by far. I'm looking at this more for landscape and occasional indoor of people. For me, rendering is many things, including sharpness. f/16 being reasonably sharp, while f/22 is distinctly softer? Edited March 16, 2021 by Pixeleater Link to post Share on other sites More sharing options...
Cobram Posted March 17, 2021 Share #13 Posted March 17, 2021 15 hours ago, Pixeleater said: I'm looking at this more for landscape and occasional indoor of people. For me, rendering is many things, including sharpness. f/16 being reasonably sharp, while f/22 is distinctly softer? For landscape I prefer Elmarit ASPH. Summicron is designed to be used wide open @f2. I can confirm my best family photos are taken at f2 with Summicron 28. But my best tree and landscape photos came from Elmarit ASPH (I sold it) and CV 21/4. Link to post Share on other sites More sharing options...
