Hi I getting so annoyed every time I use the SL2s  I turN 🥶the front dial some how as I newbie to Leica and change the exposure by x Mount of stops this happens all the time with out me knowing tried to change it but could not find any where in menu that enables this ,any ideas please thanks again PAUL
It happens when I’m in Aperture mode and I think manually,
I would like it to maybe change shutter speed or aperture ,any thing but change the exposure comp + —
thanks  had camera 2 weeks
Edited by Nash
Serious advice - based on your posts here and elsewhere, I recommend you read the manual to find out how the camera works. You will get much better advice here when you understand the basics of how the camera works and what your options are - the manual has most of it.
Edited by LocalHero1953
What do you have the front dial set up to do? Check in the menu. In terms of turning it by accident, just go out and use the camera more so you build up the muscle memory. The frustrations are here because you’re not familiar with it.
