simon_hsn Posted January 24, 2021 Share #1 Posted January 24, 2021 Advertisement (gone after registration) Hi everyone, On my SL (601) I am faced with the following issue: “[...] If there are SD cards in the camera, it will use the 8-bit codecs, regardless of whether an HDMI connection is in use. If there are no cards the signal will go out over HDMI in 10-bit depth. So take them out. This makes sense to me. I don't see how the camera would have the capacity to run both codecs simultaneously.” The topic has been already discussed here: Can anyone share their experience on that matter with the SL2-S? - Do you have to take out the SD cards to get better external recording quality? - Does the camera simultanously record, when the SD cards are in the camera while using an external recorder? Link to post Share on other sites More sharing options...
Advertisement Posted January 24, 2021 Posted January 24, 2021 Hi simon_hsn, Take a look here SL2-S HDMI output - SD card removal necessary for 10 bit?. I'm sure you'll find what you were looking for!
BernardC Posted January 25, 2021 Share #2 Posted January 25, 2021 On 1/24/2021 at 4:55 AM, simon_hsn said: On my SL (601) I am faced with the following issue: “[...] If there are SD cards in the camera, it will use the 8-bit codecs, regardless of whether an HDMI connection is in use. If there are no cards the signal will go out over HDMI in 10-bit depth. So take them out. This makes sense to me. I don't see how the camera would have the capacity to run both codecs simultaneously.” The topic has been already discussed here: That's a really old discussion. It doesn't apply to the current firmware. You can record 10-bit over HDMI with the SL if you trigger from the recorder (not the camera). The camera doesn't record to the card, so it doesn't need to convert to 8-bit. Link to post Share on other sites More sharing options...
