3 hours ago, Eclectic Man said:
Have you checked the battery contacts in the camera? If the same battery works in the q2m then they should look pretty similar.
If they are not obviously obstructed, it is probably a return to the vendor.
Thanks for the advice, the contacts in the camera are the same as the q2m and no visible signs of damage
I contacted my local Leica store who said to bring it in for a quick look over to make sure I hadn’t done something silly etc
they then changed for a new one
i have asked to be informed of what Leica says was wrong as they’ve never had an sl2 die on them
i maybe just cursed
Thanks for your input
Adrian
i maybe just cursed
Adrian
You are not cursed. This just happened to mine. I have hardly used it and just sat down to learn the camera and dead as a door nail.
  • 3 years later...
I have the same exact problem with my SL2.  Dead as a doornail.  Cleaned all the battery contacts, the battery compartment contacts, tried five different batteries (all of which work fine in my SL-2S), tried to power via a USB cable, lenses on & off, memory cards in & out, nothing works.  Not even a glimmer of an LED.  Probably will be shipping off to Leica tomorrow, for who knows how long ........
Ă—
Ă—
