leonpro Posted August 23, 2007 Share #1 Â Posted August 23, 2007 Advertisement (gone after registration) Apologies in advance if this has been discussed before, but I can't find a definitive answer if a UV filter affects photo sharpness (being another glass element in front of the lens) especially if used indoors. Â Also, people say it can be left on the lens all the time as protection, which I do. But any color shift of any kind when used indoors? Link to post Share on other sites More sharing options...
Advertisement Posted August 23, 2007 Posted August 23, 2007 Hi leonpro, Take a look here UV Filter - will it affect sharpness?. I'm sure you'll find what you were looking for!
jaapv Posted August 23, 2007 Share #2 Â Posted August 23, 2007 Yes- it will affect sharpness. I will spare you the long theoretical explanation. No- you won't notice in actual use in 95 % of your shots. No it won't produce any colour effects, except if you have a very old non-UV blocked lens. Then it may reduce some blue haze in the distance. It may produce some extra flare, so use a lens hood. A real protective filter (Heliopan) has even less negative effects and is stronger. Link to post Share on other sites More sharing options...
leonpro Posted August 23, 2007 Author Share #3 Â Posted August 23, 2007 Thanks for info. The reason I asked is that I notice the photos are not as sharp as I want to be when shooting full coverage shots versus close-up/macro shots. Perhaps I need to close the aperture a little bit more to compensate. Might be a better trade-off than scratching the glass of the lens itself. Â I am using the Leica UV filter, btw, if it matters. Link to post Share on other sites More sharing options...
