Hi folks,
I just bought a Zeiss 21mm f/4.5 (not the 2.8) for travel because it's tiny and pretty good. I am trying to determine if there is a way to 6-bit code this lens. I know flanges are available for many Zeiss ZM lenses, but have not seen one for this one. Anyone have any idea if one is available or if there is someone who can machine the flange?
Thanks,
Chuck
I have the 21mm ZM Biogon too and it's my most used lens, small and super sharp. That said, I only use it for B&W. On my old M9 and new M10 I get pretty significant red vignetting in the color file. This can be corrected using Adobe's Flat Field for Lightroom or an app called Corner Fix but it's a bit of post processing work. But for B&W its a superb lens! Cheers, jc
Leica M9
Leica M10
vor 6 Stunden schrieb jkcampbell2:
Wow, thats disappointing from a 1000$+ Zeiss Lens.
I guess that it is a problem of the lens and will be the same on other - also non Leica - cameras, or are i'm wrong?
Chris
It is an issue with light ray angles because of the (generally necessary) design of digital M cameras.
It is not an issue with film M cameras, for example, even color ones. The effects have been mitigated with each generation on digital, though.
