Photoskeptic Posted September 2, 2007 Share #21 Posted September 2, 2007 Advertisement (gone after registration) Charlie, i just sold my M4. Hated to see it go but I prefer my M3 because I only shoot film with a 50 cron and I decided to get down to just one film body. I use a yellow filter when there are clouds present. And that's it. I looked into the polarizer setup that Robert White sells in England, but rejected it because it seemed to soften the image. Your experience may be different as different film and lenses seem to react differently. Anyway, enjoy your camera. Link to post Share on other sites More sharing options...
Advertisement Posted September 2, 2007 Posted September 2, 2007 Hi Photoskeptic, Take a look here Leica m4, some questions about filter and manteniance. I'm sure you'll find what you were looking for!
ziofanale Posted September 15, 2007 Author Share #22 Posted September 15, 2007 Solved the problem of the revision: about 170€! And now I am a lot more sure of the camera "good state".. For the filter I have found a new leica filter with the right diameter (43) but it is not a simply uv filter, it is an uv/ir filter designed for the m8.. It would be a bad idea to use it on my summilux? thank-you! Link to post Share on other sites More sharing options...
luigi bertolotti Posted September 15, 2007 Share #23 Posted September 15, 2007 Solved the problem of the revision: about 170€! And now I am a lot more sure of the camera "good state".. For the filter I have found a new leica filter with the right diameter (43) but it is not a simply uv filter, it is an uv/ir filter designed for the m8.. It would be a bad idea to use it on my summilux? thank-you! ... e adesso GODITI la tua M4 fresca fresca !!!! Non so bene come si comporti l'UVIR con la pellicola... qualcuno ci avrà di certo provato... in teoria, non credo che faccia danni... dovrebbe fare il lavoro di un UV e in più bloccare certe frequenze di infrarosso, a cui peraltro le pellicole non sono sensibili. Però con i grandangolari potrebbe dare lo strano problemino cosidetto "cyan drift" ... sulla M8 viene corretto dal software, non so però se sulle pellicole si presenti, però non c'entra con il sensore digitale... ha a che fare con il filtro in se' per via di riflessioni interne dovute ai due strati filtranti (qui nel forum si impara di tutto ... ) Saluti Luigi PS : hai degli altri obiettivi ? Link to post Share on other sites More sharing options...
josephgalilee Posted November 13, 2007 Share #24 Posted November 13, 2007 I confirm that the best CLA for Leica camera in Italy you can get to SAM.CA (Sammartino e Casanova) from Genova, historical Leitz Service. They got experience to Leitz Wetzlar training service. A CLA for your M4 (for example) cost about € 250. To the end of well job they apply seal "G" on your camera. So your advance lever will be silk smooth "horse pair", neither Solmser Service will tend with this results. When i move the advance lever of my M2-R with care CLA of SAM.CA it look like the silent and sweetness smooth of the first M3. Theys still use the famous six Leitz special greases for the correct lube of ancient Leitz camera. Buona serata a tutti fratelli, tra poco tornerà il mitico marchio Leitz Wetzlar sui prodotti grazie al Dr. Kaufmann che sta preparando un ritorno a Wetzlar in grande stile con il Leitz Park. Vielehn dank Dr. Kaufmann.... for the next return to the great classic brand Leitz Wetzlar Gmbh. Wundebar! Ciao giuseppe Link to post Share on other sites More sharing options...
jc_braconi Posted November 14, 2007 Share #25 Posted November 14, 2007 Ciao Charlie ti ho lasciato un messagio personale. Auguri JC Link to post Share on other sites More sharing options...
Photoskeptic Posted November 14, 2007 Share #26 Posted November 14, 2007 Charlie, I had an M4 for about the same time as you. Incredibly sturdy bodies, won't need a CLA unless you really get something out of whack. I reluctantly let it go as I was reducing my film body collection to just an M3 which I prefer because I only use a 50 cron for film Link to post Share on other sites More sharing options...
