robgo2 Posted December 4, 2020 Share #1 Posted December 4, 2020 (edited) Advertisement (gone after registration) I realize that this is not the best choice for close up photography, but I thought I would give it a try. Unfortunately, I have not been able to attach the Elpro, even with the supplied 46 to 52 ring adapter. It will not screw into the front of the lens. I know that it is supposed to fit, so what am I missing? Is there a screw-in ring on the front of the lens that can be removed? If so, I cannot find it. Edit: I just realized that the filter size of the lens is 49mm, not 46mm. I thought that the adapter would fit, but I was wrong. I will call my dealer to sort things out. Edit 2: Hidden deep in the packaging, I found a 49 to 52mm adapter. Problem solved. BTW, I am not usually this clueless. It's just that kind of day. 🙃 Edited December 4, 2020 by robgo2 1 2 Link to post Share on other sites More sharing options...
Advertisement Posted December 4, 2020 Posted December 4, 2020 Hi robgo2, Take a look here How to attach Elpro 52 to Q/Q2 lens? . I'm sure you'll find what you were looking for!
Leica Guy Posted December 5, 2020 Share #2 Posted December 5, 2020 19 hours ago, robgo2 said: I realize that this is not the best choice for close up photography, but I thought I would give it a try. Unfortunately, I have not been able to attach the Elpro, even with the supplied 46 to 52 ring adapter. It will not screw into the front of the lens. I know that it is supposed to fit, so what am I missing? Is there a screw-in ring on the front of the lens that can be removed? If so, I cannot find it. Edit: I just realized that the filter size of the lens is 49mm, not 46mm. I thought that the adapter would fit, but I was wrong. I will call my dealer to sort things out. Edit 2: Hidden deep in the packaging, I found a 49 to 52mm adapter. Problem solved. BTW, I am not usually this clueless. It's just that kind of day. 🙃 The cluelessness could be age related. I followed along very well with your journey of discovery. I can relate. Glad you figured it it. I got a good laugh from it. Close to home. 😁😁 Link to post Share on other sites More sharing options...
acg69 Posted December 7, 2020 Share #3 Posted December 7, 2020 The real journey begins now! The setup is very good and you will get a kick out of it! There is a thread with macro pics (with and without the ELPRO 52) somewhere here; check it out and happy shooting! Link to post Share on other sites More sharing options...
robgo2 Posted December 7, 2020 Author Share #4 Posted December 7, 2020 Now that my mind has cleared, I would welcome suggestions for a small (table top) tripod to use with this setup. Link to post Share on other sites More sharing options...
PhotoCruiser Posted December 8, 2020 Share #5 Posted December 8, 2020 (edited) vor 15 Stunden schrieb robgo2: Now that my mind has cleared, I would welcome suggestions for a small (table top) tripod to use with this setup. The problem on a small table top tripod is that camera and elpro is heavy and tippy. After several tests i settled with the GorillaPod Rig because the long legs keep the camera from falling forward and the two additional light arms can hold a small light panel to illuminate the scenery. If you dont like GorillaPods then look for a Tripod with long legs to avoid that the camera tip over Chris PS: And you need a tripod who is low and the legs can be bent 90° so that the tripod is flat on the surface and less high possible, if it's too high then you will take pix from too above and in a bad angle. I started to use a normal tripod on the floor as this gives me the possibility to have the lens on the same level as the scenery Edited December 8, 2020 by PhotoCruiser 1 Link to post Share on other sites More sharing options...
