tm35 Posted December 6, 2020 Share #21 Posted December 6, 2020 Advertisement (gone after registration) Thanks for replying. I scanned using Plustek 8200i. But I could see the issue by looking the negative itself for both vertical and horizontal bands, so we can rule out the scanning issue. The only shot on this roll that don't have both vertical and horizontal bands is the first shot, the rest has both of them and very consistent pattern. It is possible that the first shot were shot at lower shutter speed. I don't see any of these problem on previous rolls at all (but they were shot at most 1/250). Link to post Share on other sites More sharing options...
Advertisement Posted December 6, 2020 Posted December 6, 2020 Hi tm35, Take a look here M6, light leak or bromide drag? . I'm sure you'll find what you were looking for!
giannis Posted December 21, 2020 Share #22 Posted December 21, 2020 On 11/20/2020 at 4:56 PM, emilkarl said: Here is some pictures of the negatives + scans. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! It's very clearly a lightleak. Look at the right edge, it's completely burnt! You can even see double impressions of the sprocket holes, this means light leaked through and "projected" the sprocket holes of the outer layers of the film onto the inner ones, creating those outlines. This usually happens when there's a lightleak hitting the takeup spool area, where the film is wound. If you're certain the lightleak didn't originate in the camera, the only other options could be either during loading to the reels for development, or a lightleak in the dev talk, or, with very small likelihood, a faulty/damaged film canister. If there's any bromide drag it'd have to be on top of the severe lightleak. It's implausible that you have bromide drag with the developer and agitation you descrbed. Link to post Share on other sites More sharing options...
