Gers Posted November 5, 2020 Share #1 Posted November 5, 2020 Advertisement (gone after registration) I am having trouble getting the firmware 3 onto my card. I have downloaded it; it is on my computer but when I try to put it on the card I geta message asking me to put a disk in. I have tried 3 different card readers and nothing changes. Yes I have checked that the card is not write protected and formatted it in the camera. I got my settings onto it so there is nothing wrong with the card. I consider myself to be reasonably computer savvy so do't know what is happening. Any ideas? Can you help please. Link to post Share on other sites More sharing options...
Advertisement Posted November 5, 2020 Posted November 5, 2020 Hi Gers, Take a look here Firmware troubles; Help needed . I'm sure you'll find what you were looking for!
Simone_DF Posted November 5, 2020 Share #2 Posted November 5, 2020 Are you on macOS or Windows? Link to post Share on other sites More sharing options...
Gers Posted November 5, 2020 Author Share #3 Posted November 5, 2020 1 hour ago, Simone_DF said: Are you on macOS or Windows? windows 7 Link to post Share on other sites More sharing options...
pop Posted November 5, 2020 Share #4 Posted November 5, 2020 Can you put other files on the card, such as .jpg or .txt ? How are you trying to move the file to the card? Link to post Share on other sites More sharing options...
Gers Posted November 5, 2020 Author Share #5 Posted November 5, 2020 Yes I have put my profiles onto the card. I have tried dragging & dropping & 'send to' but nothing works. I had this problem when installing previous firmware update but eventually one of the readers worked Link to post Share on other sites More sharing options...
pop Posted November 5, 2020 Share #6 Posted November 5, 2020 Sorry, I should have asked whether you have written other files to the card under Windows. Anyway, if you open the card with the Explorer, can you see your profiles and any directories? Can you create new directories using the Explorer? Link to post Share on other sites More sharing options...
Gers Posted November 5, 2020 Author Share #7 Posted November 5, 2020 Advertisement (gone after registration) When I try to put other files onto card it just comes up with the same message Link to post Share on other sites More sharing options...
pop Posted November 5, 2020 Share #8 Posted November 5, 2020 Can you open the card with the Windows Explorer? Can you see in Windows what's on the card? Link to post Share on other sites More sharing options...
Gers Posted November 5, 2020 Author Share #9 Posted November 5, 2020 I could but now I can't Link to post Share on other sites More sharing options...
pop Posted November 5, 2020 Share #10 Posted November 5, 2020 There you are. Windows can not "see" the card or the card reader. I would suggest restarting the computer. When the problem persists and the card is otherwise empty, you might want to try and format the card with Windows (using one of the FAT or DOS formats). Using another card reader might help. I am not all that familiar with Windows 7, but it's an elderly OS. How large is the card you are trying to use, and does it make a difference if you use a much smaller card? Link to post Share on other sites More sharing options...
Gers Posted November 5, 2020 Author Share #11 Posted November 5, 2020 No good nothing works Link to post Share on other sites More sharing options...
jaapv Posted November 5, 2020 Share #12 Posted November 5, 2020 Windows7 is no longer supported - I would try another computer, and format the card in SD-formatter first. Link to post Share on other sites More sharing options...
bjamisonf Posted November 6, 2020 Share #13 Posted November 6, 2020 It happened to me as well but that was when I was trying to move the firmware update to the DCIM folder. When I moved it to the lower level base folder, it worked with no issue. Link to post Share on other sites More sharing options...
Gers Posted November 6, 2020 Author Share #14 Posted November 6, 2020 There MUST be a way round this; Nobody out there got any ideas? Link to post Share on other sites More sharing options...
pop Posted November 6, 2020 Share #15 Posted November 6, 2020 vor einer Stunde schrieb Gers: Nobody out there got any ideas See #10 above? Link to post Share on other sites More sharing options...
Gers Posted November 6, 2020 Author Share #16 Posted November 6, 2020 WhenI try to format it just comes up with the same old 'insert a card' message. I have tried more than one card reader Link to post Share on other sites More sharing options...
LexS Posted November 6, 2020 Share #17 Posted November 6, 2020 (edited) I propose following: put the card in your camera, format the card in your camera; connect the card to the computer, put the firmware from the computer onto the card (direct, not in a folder); disconnect the card from the computer, put it in the camera, run the update from the card. AFAIK it has nothing to do with what OS is on the computer. AFAIK the firmware is now level 3.1 for Q1 and 3 forQ2. Procedure always the same. Edited November 6, 2020 by LexS Link to post Share on other sites More sharing options...
Gers Posted November 6, 2020 Author Share #18 Posted November 6, 2020 13 minutes ago, LexS said: I propose following: put the card in your camera, format the card in your camera; connect the card to the computer, put the firmware from the computer onto the card (direct, not in a folder); disconnect the card from the computer, put it in the camera, run the update from the card. AFAIK it has nothing to do with what OS is on the computer. AFAIK the firmware is now level 3.1 for Q1 and 3 forQ2. Procedure always the same. That is EXACTLY what I have done but all I get is the SAME message!!!!! Link to post Share on other sites More sharing options...
ianforber Posted November 6, 2020 Share #19 Posted November 6, 2020 Do you have a friend who could download it onto a card for you and then post it to you (or if your lockdown rules allow, just hand it over direct)? Link to post Share on other sites More sharing options...
pibitller Posted November 6, 2020 Share #20 Posted November 6, 2020 1. Format the card in PC with format exFat 2 Format de Card in camera 3 Copy the firmware in PC to card 4 Insert the card in camera and install de firmware Link to post Share on other sites More sharing options...
