nineteenfocus Posted October 18, 2020 Share #1  Posted October 18, 2020 Advertisement (gone after registration) If I set a summicron 50mm at f8 for zone focus, is acceptable sharp at infinity? I find that if I focus to infinity the image is sharper. Any thoughts? Link to post Share on other sites More sharing options...
Advertisement Posted October 18, 2020 Posted October 18, 2020 Hi nineteenfocus, Take a look here Zone focus summicron 50mm. I'm sure you'll find what you were looking for!
pedaes Posted October 18, 2020 Share #2  Posted October 18, 2020  26 minutes ago, nineteenfocus said: If I set a summicron 50mm at f8 for zone focus, is acceptable sharp at infinity? I find that if I focus to infinity the image is sharper. Any thoughts? If you align infinity mark with (f) 8 it should be more than acceptable sharp. As the lines are so close, set at f8 but align with 5.6 for safety. Also use centre of infinity symbol - check how it looks on centre mark. Link to post Share on other sites More sharing options...
andybarton Posted October 18, 2020 Share #3  Posted October 18, 2020 IIRC, the depth of scale indications on lenses were set for their use on film cameras. Digital sensors are absolutely flat and less forgiving than a floppy piece of plastic negative, so that is why it is sensible/good practice to use the next aperture mark down instead of the one you are using. Link to post Share on other sites More sharing options...
Ko.Fe. Posted October 18, 2020 Share #4  Posted October 18, 2020 Not sure if here is any difference between film and digital at f8. But I used my 50 Cron with scale focusing on film at different distances and it was fine. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  Link to post Share on other sites Simply register for free here – We are always happy to welcome new members!  ' data-webShareUrl='https://www.l-camera-forum.com/topic/314310-zone-focus-summicron-50mm/?do=findComment&comment=4064786'>More sharing options...
nineteenfocus Posted October 18, 2020 Author Share #5  Posted October 18, 2020 7 minutes ago, Ko.Fe. said: Not sure if here is any difference between film and digital at f8. But I used my 50 Cron with scale focusing on film at different distances and it was fine. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members!  nice pic. did u use zone focusing in this one? inf is not sharp 1 Link to post Share on other sites More sharing options...
Ko.Fe. Posted October 18, 2020 Share #6  Posted October 18, 2020 Just now, nineteenfocus said: nice pic. did u use zone focusing in this one? inf is not sharp This is why I posted it here. How else you focus with M on walking person and while keep on walking. Cron with focus tab ain't difficult for quick scale focusing, BTW. I wrote about many times. Here is direct relation between focus tab position and focus, DOF scale. With practice no need to look at focus scale at all. Link to post Share on other sites More sharing options...
pippy Posted October 18, 2020 Share #7  Posted October 18, 2020 (edited) Advertisement (gone after registration) 1 hour ago, nineteenfocus said: If I set a summicron 50mm at f8 for zone focus, is acceptable sharp at infinity? I find that if I focus to infinity the image is sharper. Any thoughts? At any focus point only the area which is focussed on will be perfectly sharp so it should be no surprise to discover that subject-matter at infinity is sharper than anything nearer if you focus at infinity. By the same reasoning if you focus closer-in then infinity will not be in focus. The indices either side of 'actual' focus are only to be used as a rough guide to the distances in front of- and behind the actual focus point in terms of what might be deemed to be 'sharp-enough' for normal purposes. Obviously the nearer to the 'actual' focus point the sharper these zones will be and as a lens is stopped-down more appears to be 'more in focus' but they will never be 100% sharp. Comparing what is 'in focus' of a landscape scene (for instance) on a 15cm x 10cm print is a very different proposition from viewing the same image printed to 90cm x 60cm and what is considered to be 'acceptably sharp' is a purely personal judgement. Philip. Edited October 18, 2020 by pippy 1 2 Link to post Share on other sites More sharing options...
