  • 3 weeks later...
42 minutes ago, feelssadman said:
If you take the bottom plate off and remove the SD card you should see a slit. Insert a coin. It should work again afterwards. If not, you will have to transfer a small sum to a friend of mine in Nigeria.
You neglected to add that the coin must be gold.
  • 2 months later...
This problem seems to be happening intermittently, especially when I replace a charged battery.
Since the level gauge is dependent on the built-in accelerometer, maybe the latter is stuck. Any thoughts on how to fix this?
Of course, a reset works, but it is a pain, to do it each time and to reload all profile settings..
Edited by rramesh
5 minutes ago, erniethemilk said:
Have you got the level gauge switched on in the capture assistants menu option?
I believe you can switch the display to show information in live view and this also displays or does not display the level gauge also.
Yup, tried this. Somehow the accelerometer gets stuck and a couple of resets and it is fixed. It's a technology perfected and implemented in most mobile phones, but it would seem that Leica is still grappling with it.
Edited by rramesh
  • 3 years later...
