That works for the M8 and M9. But not later M digitals.
Once video and live-view were added with the M(typ 240) and later CMOS cameras, it is no longer a reliable method. Reason being that the shutter can be actuated many times for live-view - without actually producing a picture file with a unique image ID to test.
Important point of logic and language. All M9s are M digitals, but not all M digitals are M9s. ;)
Just to add- On the M8 using the "button dance", the "DEBUG" mode ends once the power is turned off.
I did the M9 button dance once time: I had to reload the Firmware using the standard procedure of copying it to the SD card to get the camera back to normal mode. The difference- the "bad pixel Mapping" stopped working in Debug mode. That was with an older version of firmware, 1.174. I've not tried it since.
  • 2 weeks later...
The M262s don't have live view and the M-D and M10-D do not even have a screen but still they're lacking the count information in the files 😜
So, how do we retrieve the shutter count from newer Ms?
You don’t.
Apparently, maybe you can, via this software: https://transienteye.com/software/
Mentioned in this thread:
BTW - that thread mentions that the Leica unique Picture IDs are now hashed - converted to a number of constant length that only means anything to a computer with an appropriate look-up table and function to decode it. The software mentioned provides the decoder, it seems.
https://en.wikipedia.org/wiki/Hash_function
But it is still only a count of pictures taken, and will only reflect shutter actuations (approximately) if one never uses video, live-view - OR an EVF (M10-D), which is just live-view via a different viewing screen.
Leica's firmware writers do not consider it an important feature that users can read their own shutter counts easily.
