On 8/23/2020 at 8:44 AM, ckuwajima said:
This is the view from a M4 with Summilux-M Pre-Asph set at infinite.
Wow, only 35mm frame lines look so good. I would love to cover the 135mm lines and leave 35 + focus patch only.
One day
One day
Actually M4 have 135mm framelines, but they are small (only the 4 frame corners) and very faint (at least on my camera).
I didn't see it. Now yes, I did. Very small and unobtrusive. Love it. If one uses mostly 35FL, w/ doubt the 135 frame lines are in the way.
One day, I'll probably buy one M film camera a la carte. Or I will find someone taping my frame lines on my M10 😎 I know it's not easy, nut possible
a version 1 of the nokton, no hood but with lens cap.
  • 3 weeks later...
My Nokton 35 f/1.2 V2 with no hood - a bit problematic to compose or anticipate but I am the guy who observe with left eye so can deal with it...
Might be helpful for someone who thinks about buying :)
It's big, but not so bad. I heard it's a great modern lens ... Some prefer v2 because less sharp.
Yes it is, this is what the thread is about. To collect more OVF views as possible.
Thanks for sharing
My 35 Pre Asph Summilux is invisible without the shade, put the shade on and there is minimal blockage on my M3 (M4 viewfinder). No choice to put a filter on it as the shade holds the filter. I have had the lens for years and I barely noticed it. Didn't like my viewfinder images.
35mm Summarit f/2.5 at infinity, with and without 3rd party vented hood
Voigtlander 35mm Nokton f/1.2 v3, at infinity
With my (admittedly both Ancient and Slow) non-goggled 1954 35mm f3.5 Summaron-M there is absolutely no finder cut-off whatsoever when there is no hood used at any focussing distance. With my lens I use a 12585 vented hood and the cut-off is still (almost) nil. Slight arc of edge of hood is about as bad as it gets. The actual lens never intrudes.
The upside - for me - to the Ancient and Slow bit is that I get really beautiful rendering with rectilinear results from an incredibly tiny lens which is almost never used with apertures faster than f5.6 in any case so the 'slow' f3.5 isn't an issue for me.
I'm pretty sure I will be amongst a tiny minority of Leica-M users who own no other 35mm M-mount lens than the f3.5 Summaron. I'm not a huge fan of the 35mm f/l.
Sorry if that didn't help one little bit, Dennis!
Philip.
Edited by pippy
You helped a lot. Look what you just said
It's a fantastic statement 🙂
It's a very light blockage, very helpful for composition.
Just wonder if the blockage it would be similar on the new release CV 35/2 Apo ... similar size/dimension?
No hood here, right?
7 minutes ago, Al Brown said:
(But seriously, I do not even see that lower right corner of the hood anymore. No bother whatsoever.)
agree. Yesterday I tried for the first time with a big lens to shoot in vertical, and I was horrified. I quickly changed my mind 🙂
Good thing when framing vertical, we can choose left-bottom or right-top.
Had you tried the two choices Dennis ?
Yes, both. Coming form SLR like Nikon FM, the film lever almost "must" to be on top, right? It's the right way. With my M10, I feel the same. The contrary it feels unnatural IMHO
Oddly enough this last point brings up an earlier discussion we were having over in the 'One Aperture' thread where night-time snaps / slow shutter speeds were mentioned. Although the way you (and Arnaud) describe holding the camera is the 'normal' being, as it usualy found to be, the most comfortable and convenient option there is much to back up the idea that the 'converse' is most useful when slow speeds are required as the photographer can use his/her forehead and nose as a steadying / bracing point when holding the body of the camera against them. 'T'was thus that I held the camera the other night.
Like (almost) everyone else I adopt the 'normal' method...erm...normally but when slow speeds are required I generally go 'Converse'.
Give it a go; you might not like the experience but you might like the end results!
Philip.
Philip.
Awesome, it totally makes sense Philip, thank you! I have to try. Because I shoot vertical only when it's very needed. Let's say when documenting, with an M, 97% could easily be horizontal orientation. When it's an assignment or general work, I don't use yet a Leica so with DSLR is easy. But i'll definitely try this.
Actually I'm sure i tried it already, couple of times. But it didn't catch me. This time, I'll do it with conscience 🙂
Edited by Dennis
