Nachapon Dumrongthumavoot Posted August 13, 2020 Share #1 Posted August 13, 2020 Advertisement (gone after registration) Hi, i have been experiencing strange issue with CF card from Sandisk. I recently receive Leica s3 and bought 128gb extreme pro sandisk CF card to use with it. Lately there is a certain issue that keep appearing. Every time that i import the picture to the lightroom, the next batch of images will have a corrupted first file that show zero data on the file when i'm importing it. Before importing the next batch of files, i can look at that first image just fine on the camera, but once it is on the card reader, the first file will be corrupt and can no longer be seen on the pc or on the camera. I tried formatting the card several time both in camera and on the pc but the problem still occur. After that i try switching to another sandisk 64gb CF card that i used with the S2 but the problem still occurs. However, when i used the old 16gb lexar CF card, the problem does not occur. So anyone have any clue on what is happening with the sandisk CF card? i believe the sandisk 64gb card that i used never had this problem with the S2 before. Am i missing some setting on the S3 such as file numbering that might cause this issue? Thank you Link to post Share on other sites More sharing options...
Advertisement Posted August 13, 2020 Posted August 13, 2020 Hi Nachapon Dumrongthumavoot, Take a look here Anyone experiencing strange compatibility issue with Sandisk CF card?. I'm sure you'll find what you were looking for!
Petrus61 Posted August 13, 2020 Share #2 Posted August 13, 2020 Mine turned out to be a slightly bent pin in the CF slot. Leica changed the complete camera as soon as they were able due to Covid restrictions. I am using Sandisk 128 CF and works fine ... sorry Link to post Share on other sites More sharing options...
LeicaR10 Posted August 14, 2020 Share #3 Posted August 14, 2020 Nachapon Dumrongthumavoot, I don't use any card over 32 for minimizing issues. I found the issue you described in the S007 when i tried several CF 64/128 cards as an experiment. I normally used Sandisk and Hoodman CF cards with the S007. Right now for the S3, I moved to Hoodman SD 16 and 32s with no issues. I don't use CF cards to minimize the potential of bending pins. Hope this helps. r/ Mark Link to post Share on other sites More sharing options...
Nachapon Dumrongthumavoot Posted August 14, 2020 Author Share #4 Posted August 14, 2020 Thank you for your reply. At least now i know that this problem does occur to others as well. I will follow your suggestion and using multiple smaller SD and CF cards to avoid such problem. Thank you again. Link to post Share on other sites More sharing options...
