rarara Posted June 24, 2020 Share #1 Posted June 24, 2020 Advertisement (gone after registration) hi all. recently acquired an 1995 M6 Classic but frame lines don't seem to change w/ different lenses. Pretty sure I have a 0.72 viewfinder and with a 35mm lens the brighter frame lines are at the border of the viewfinder, which seem correct... but when i change to a 50mm lens, the same frame lines stay bright. Moving the frame line preview lever does nothing either? Also, is that lever supposed to stay in centre default, and then spring inward & outward to preview... or supposed to be able to switch b/t inward, centre & outward? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/310846-m6-classic-framelines-not-changing/?do=findComment&comment=3998581'>More sharing options...
Advertisement Posted June 24, 2020 Posted June 24, 2020 Hi rarara, Take a look here M6 Classic Framelines Not Changing? . I'm sure you'll find what you were looking for!
AndreasG Posted June 24, 2020 Share #2 Posted June 24, 2020 Usually the frame line lever is movable by hand easily left and right from its central position, with and without lens attached, showing the three different pairs of frame lines. Seems, in your case there is a mechanical issue, something stuck in the rangefinder optical system (shock?) or so. Difficult to give any advice without having the camera at hand, probably a case for the Leica or other professional service. Link to post Share on other sites More sharing options...
rarara Posted June 24, 2020 Author Share #3 Posted June 24, 2020 2 minutes ago, AndreasG said: Usually the frame line lever is movable by hand easily left and right from its central position, with and without lens attached, showing the three different pairs of frame lines. Seems, in your case there is a mechanical issue, something stuck in the rangefinder optical system (shock?) or so. Difficult to give any advice without having the camera at hand, probably a case for the Leica or other professional service. thanks for your reply @AndreasG.. it's definitely looking like a repair is required Link to post Share on other sites More sharing options...
oldwino Posted June 24, 2020 Share #4 Posted June 24, 2020 I had that with my MP - it was just some dirt in the frame lines masks which prevented them from sliding properly to the correct position. Link to post Share on other sites More sharing options...
pixie Posted June 25, 2020 Share #5 Posted June 25, 2020 My M6 TTL frame selector, manually or inserting lens! It reqd. a Leica Technician for that. My M3 and M2 never ever had this problem.. My M6 TTL frame counter never works properly due to a "plastic" spring! Link to post Share on other sites More sharing options...
tommonego@gmail.com Posted June 25, 2020 Share #6 Posted June 25, 2020 I bought an M8 with a 40mm CV on it, the seller said it was the only lens that he had on the camera. The frame lever was stiff, but it has worked itself out in a year. Nobody except Leica will open an M8 and I didn't want to send it in, too many stories, the camera works well except for the framing but now that is OK. Link to post Share on other sites More sharing options...
Charles Morgan Posted June 26, 2020 Share #7 Posted June 26, 2020 Advertisement (gone after registration) i had an M2 that would not engage the 90mm framelines. They get damaged, but it wasn't a big or expensive repair to sort. Good luck! Link to post Share on other sites More sharing options...
