wilsont Posted June 19, 2020 Share #1  Posted June 19, 2020 Advertisement (gone after registration) hi all  I followed the instructions to the letter and since click do the initial options, the back screen has been black and the top LCD is on. It has been going about 2 hours? Can anyone else advise on how long it took them? if there is a problem, not sure whether to interrupt it?  thanks in advance,  richard Link to post Share on other sites More sharing options...
Advertisement Posted June 19, 2020 Posted June 19, 2020 Hi wilsont, Take a look here Firmware update problems?. I'm sure you'll find what you were looking for!
jaapv Posted June 20, 2020 Share #2 Â Posted June 20, 2020 If it has been black for two hours it will be so until the battery runs down which will switch off the camera anyway. Pull the battery, replace with a fully recharged one, download the software again, use a freshly;y formatted card, put the file on the card, switch on the camera whilst praying that it will restart and do the rest of the procedure again. Make sure that you did not misread anything. Link to post Share on other sites More sharing options...
masjah Posted June 20, 2020 Share #3  Posted June 20, 2020 12 hours ago, wilsont said: hi all  I followed the instructions to the letter and since click do the initial options, the back screen has been black and the top LCD is on. It has been going about 2 hours? Can anyone else advise on how long it took them? if there is a problem, not sure whether to interrupt it?  thanks in advance,  richard It only took a few minutes to install on my camera. Was the bottom red LED flashing whilst this was going on? Had you locked your SD card after downloading the firmware file on to it? I haven't the faintest idea whether this makes any difference, but mine was not locked,  just in case the camera wanted to write some information on to it to pick up later, if you see what I mean. Just a thought. Link to post Share on other sites More sharing options...
wilsont Posted June 20, 2020 Author Share #4  Posted June 20, 2020 thanks all. In the end i took the battery out and put a fresh one in and everything seems to be working (it hasn't updated the firmware but it had copied the settings onto the card  so there was an extra file there). I'm really unsure why it went wrong but am hesitant to try again as it doesn't sound like there is that much change (can't see myself using the 187mb files!) thanks all for your help, bw richard Link to post Share on other sites More sharing options...
o2mpx Posted June 22, 2020 Share #5  Posted June 22, 2020 It had been a saga. Had similar experience where screen was black after restart for a long time and didn’t seem to restart normally. Battery fully charged.  After restart, black screen returned again and sat idle. Turned camera off and pulled SD card out to insert into computer which was not recognized and could not be formatted. Tried both Windows and Mac laptops and Windows couldn’t reformat as card was in “raw” format; finally managed to have card formatted in Mac.  Placed card in camera and camera showed card was not formatted so had card reformatted and camera seems to be operational.   Link to post Share on other sites More sharing options...
Warren Guthrie Posted March 12, 2022 Share #6  Posted March 12, 2022 My SL2 does not recognize the 3.0 firmware update in camera information. I formatted the SD card, downloaded 3.0 dragged it to the SD card, but it isn't recognized.  What to do? Link to post Share on other sites More sharing options...
