Peters Posted June 3, 2020 Share #1 Posted June 3, 2020 (edited) Advertisement (gone after registration) So a few years back a few photographers found that you can screw on the Ricoh GW-3 wide angle lens converter (originally made for the Ricoh GR) onto the Leica Q to obtain a 21mm field of view. When shot at a relatively small aperture of F8-F11, the results are reasonable. A thread on the GW-3 to Leica Q experiment can be found in the German forum here: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiDn8mh1uTpAhUKfd4KHWqTBgsQFjAAegQIARAB&url=https%3A%2F%2Fwww.l-camera-forum.com%2Ftopic%2F269202-leica-q-21-mm-rico-gw3%2F&usg=AOvVaw3d6A_4pPHiIEPkEjTZgi46 Now that Ricoh has released the GW-4, which appears to be a very significant improvement over its predecessor, I was wondering if anyone has tried this out? Would be very interested in regards to sharpness at wider apertures, and ability to handle flare. Regards Edited June 3, 2020 by Peters 1 Link to post Share on other sites More sharing options...
Advertisement Posted June 3, 2020 Posted June 3, 2020 Hi Peters, Take a look here Leica Q and wide angle converter / GW-4 . I'm sure you'll find what you were looking for!
Sandokan Posted June 3, 2020 Share #2 Posted June 3, 2020 +1 - following this topic and giving it a bump. Link to post Share on other sites More sharing options...
Leica28 Posted June 3, 2020 Share #3 Posted June 3, 2020 Bump? Anyway, I haven't used that particular one. I do have the Century .55 W/A adapter left over from my 16mm & 35mm motion picture days. It's a 58mm thread so I step down to 49mm. Works pretty good (math works out to a 15.4mm) - but I never use it, preferring instead the 28mm focal length. I tried it once for giggles and it's just too wide for me. If I was wanting a wider angle of view than 28mm I would opt for 17mm. To each his own though. Link to post Share on other sites More sharing options...
Peters Posted June 3, 2020 Author Share #4 Posted June 3, 2020 2 hours ago, Leica28 said: Bump? Anyway, I haven't used that particular one. I do have the Century .55 W/A adapter left over from my 16mm & 35mm motion picture days. It's a 58mm thread so I step down to 49mm. Works pretty good (math works out to a 15.4mm) - but I never use it, preferring instead the 28mm focal length. I tried it once for giggles and it's just too wide for me. If I was wanting a wider angle of view than 28mm I would opt for 17mm. To each his own though. Sounds interesting. Could you share with us photos? Would be good to check out the level of sharpness particularly at 1.7. Link to post Share on other sites More sharing options...
nariza7 Posted November 13, 2023 Share #5 Posted November 13, 2023 Any recent findings on a working wide angle converter for the Leica Q3? Link to post Share on other sites More sharing options...
LOWapproach Posted February 29, 2024 Share #6 Posted February 29, 2024 I picked up a Ricoh GRIII and did not really care for it much, however I also picked the Ricoh GW-4 Wide Angle Converter , all worked great, perfect glass on my Q, great sharpness and colors, let me know if you like to see samples! Link to post Share on other sites More sharing options...
