Hddvt Posted May 22, 2020 Share #1 Posted May 22, 2020 Advertisement (gone after registration) My new Q2 will stop focusing on auto AND won’t focus manually. I’ve found I can shut camera off then it works again. Link to post Share on other sites More sharing options...
Advertisement Posted May 22, 2020 Posted May 22, 2020 Hi Hddvt, Take a look here Stops focusing. I'm sure you'll find what you were looking for!
johntobias Posted May 22, 2020 Share #2 Posted May 22, 2020 Well that’s not correct......?firmware update, reset and if still same....back to dealer 🙄 Link to post Share on other sites More sharing options...
Leica Guy Posted May 22, 2020 Share #3 Posted May 22, 2020 I would carefully check the lock / switch on the lens and make certain it’s in the AF position. It sounds like to me it may be half closed. Good luck. Link to post Share on other sites More sharing options...
leicameech Posted May 23, 2020 Share #4 Posted May 23, 2020 Call the Leica store/dealer! Troubleshooting with someone holding the same camera can be very helpful. Link to post Share on other sites More sharing options...
Siriusone59 Posted May 23, 2020 Share #5 Posted May 23, 2020 This problem has come up in the past and like Leica Guy said, it's usually related to the lock button that must be depressed when turning the ring to AF and the button should pop back out in that position. However the original post says it also won't focus manually either which makes me wonder if something else could be out of place or has become disconnected. A trip to Leica might be required for that repair. 1 Link to post Share on other sites More sharing options...
