wolan Posted April 6, 2020 Share #1 Posted April 6, 2020 Advertisement (gone after registration) Hi not long ago I have seen a video where a guy suggests a power pack to recharge Leica batteries while out shooting. I can't find the video anymore, do you know some product that can help here ? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted April 6, 2020 Posted April 6, 2020 Hi wolan, Take a look here Power pack for M10 batteries?. I'm sure you'll find what you were looking for!
Good To Be Retired Posted April 6, 2020 Share #2 Posted April 6, 2020 Actually, I have a Paul C Buff Vagabond power pack that I use for strobes in the field and thought about using it for this exact purpose. Plug the factory charger into the Vagabond. I'd have to research whether the mfgr of the power pack would consider that an acceptable use first. Except that it's a lot heaver than a bunch of spare batteries and less convent than the car charger. Still, I can envision occasions where it might be useful. Link to post Share on other sites More sharing options...
LeicaS2 Posted April 7, 2020 Share #3 Posted April 7, 2020 Nitecore has chargers that are powered off USB. Josh at Leicastoremiami has review them https://www.reddotforum.com/content/2018/10/its-here-the-leica-m10-usb-dual-battery-charger-by-nitecore/ https://www.nitecorestore.com/ULM10-Pro-Charger-for-Leica-BP-SCL5-Batteries-p/chg-nite-ulm10pro.htm I have not ordered one yet, but if you match it with most any USB battery pack, I would think it would do the job for you without using a larger batter pack that does 120 Volts. 1 Link to post Share on other sites More sharing options...
wolan Posted April 8, 2020 Author Share #4 Posted April 8, 2020 9 hours ago, LeicaS2 said: Nitecore has chargers that are powered off USB. Josh at Leicastoremiami has review them https://www.reddotforum.com/content/2018/10/its-here-the-leica-m10-usb-dual-battery-charger-by-nitecore/ https://www.nitecorestore.com/ULM10-Pro-Charger-for-Leica-BP-SCL5-Batteries-p/chg-nite-ulm10pro.htm I have not ordered one yet, but if you match it with most any USB battery pack, I would think it would do the job for you without using a larger batter pack that does 120 Volts. Thank you. In the meantime I did some research and found this article: https://www.nylon.com.sg/2019/02/my-leica-m10-p-setup-hacks-and-troubleshooting-the-fotos-app/ It suggests basically to buy the Nitecore and combine it with a power bank. Where I am not sure now is: what kind of power bank to buy? What characteristics should it have? Thank you. Link to post Share on other sites More sharing options...
LeicaS2 Posted April 8, 2020 Share #5 Posted April 8, 2020 I have a Nitecore for the CL batteries and just used a decent sized pack for $50.00. Might as well make sure it has 20,000 mAh or you won't get many charges. https://www.amazon.com/TalentCell-Rechargeable-11000mAh-20000mAh-Portable/dp/B01337QXMA?ref_=ws_cp_df6d79288055bc87b432_p_3_i_p Link to post Share on other sites More sharing options...
Gobert Posted April 11, 2020 Share #6 Posted April 11, 2020 (edited) I would suggest to use a Goal Zero Yeti for this purpose. You can connect various chargers via 230 and/or USB. Edited April 11, 2020 by Gobert Link to post Share on other sites More sharing options...
