Michael-IIIf Posted August 29, 2007 Share #21 Posted August 29, 2007 Advertisement (gone after registration) Shiruko, Nice shots indeed. You are off to a good start in the world of home cooking. What I find works for me is: (1) Stop rewinding before the film disappears into the canister. This is easy to feel from the tension on the rewind lever - and the noise. (2) Trim the leader square with a pair of scissors, trying to cut between the perforations rather than through them because this gives an uncluttered leading edge less likely to jam. (3) Find all the tank bits (Paterson) and lay them out in my bathroom (still haven't got around to buying a changing bag). (4) Ensure the spool is 100% dry from last use. This is essential, any humidity will cause the film to jam. (5) Place the leading edge into the spool. (6) Switch off light. (7) Load spool. (8) Tear off the canister from the end of the film. (9) Put the spool into the tank and close. This really is quick when you get a bit of practise. Which makes me remember all those cries of pain and anguish coming from my college classmates as a dozen of us tried to do this for the first time in total darkness Michael Link to post Share on other sites More sharing options...
Advertisement Posted August 29, 2007 Posted August 29, 2007 Hi Michael-IIIf, Take a look here First time BW developing woes, HELP please. . I'm sure you'll find what you were looking for!
christer Posted August 29, 2007 Share #22 Posted August 29, 2007 Shiruko, (still haven't got around to buying a changing bag). Michael if and when you get aroundd to buying a changing bag, make sure you get a generous size one - unless you use the smallest size Paterson tank. chris Link to post Share on other sites More sharing options...
