Leipen Posted January 28, 2020 Share #1 Posted January 28, 2020 Advertisement (gone after registration) I am trying to remove the front hood of the Summicron-R 90 (the 1977-2000 type, with the 2-piece hood), but I'm having a hard time. I have tried, unsuccessfully, at unscrewing the top ring on the final hood piece (see A in pic below), the printed ring (see C) and the what seems another ring (see D). The only ring I have managed to unscrew (without extracting it, however) is the one inside the hood (see B ) which enables the first hood piece to go just below the barrel's end, but then nothing moves much from there, as the final hood still can't go below there. Is there something I'm missing? Screws that need to be removed to unlock? Thanks Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/305835-how-do-i-remove-the-front-hood-summicron-r-90mm-2-piece-hood/?do=findComment&comment=3901457'>More sharing options...
Advertisement Posted January 28, 2020 Posted January 28, 2020 Hi Leipen, Take a look here How do I remove the front hood? - Summicron-R 90mm (2-piece hood). I'm sure you'll find what you were looking for!
Pnoo Posted March 8, 2021 Share #2 Posted March 8, 2021 Following. Did you solve this? Link to post Share on other sites More sharing options...
sekwenza Posted March 13, 2021 Share #3 Posted March 13, 2021 I have the same lens and have a similar issue. I managed to remove what you list as A and B on your post but now I can't get them back on.. Hood won't go up enough for me to screw them. Was on a shoot and hastily took the rings off to screw on a regular screw onND (usually I use mattebox) and then I couldn't get them back on. Link to post Share on other sites More sharing options...
LEslie_81 Posted November 6, 2022 Share #4 Posted November 6, 2022 Did anyone find out how to do this? Link to post Share on other sites More sharing options...
Leipen Posted November 8, 2022 Author Share #5 Posted November 8, 2022 Not me, sorry Link to post Share on other sites More sharing options...
monkT Posted November 8, 2022 Share #6 Posted November 8, 2022 under the Frontring there is a small screw first you have to remove the label ring ,its only glued the you can lock the ring inside good luck Link to post Share on other sites More sharing options...
davidmknoble Posted November 19, 2022 Share #7 Posted November 19, 2022 Advertisement (gone after registration) Just curious why one might want to remove the hood on this lens? Link to post Share on other sites More sharing options...
Egmenendez Posted December 18, 2023 Share #8 Posted December 18, 2023 Hi! I ´m having the same problem, do you solve it? And how?! @monkT you said that the label ring it´s glued? How do you unglued? And this label ring it´s C? Thanks a lot Link to post Share on other sites More sharing options...
BrianSVP Posted February 14 Share #9 Posted February 14 (edited) Replying to an old topic, but this might be useful to some: The printed name ring on the front that says "Leitz Canada" ("C" in Leipen's image) can be unscrewed with a friction tool, allowing the entire telescoping hood to slide off the front. You will see on the inner barrel four set screws. You don't have to remove any of the other rings. It is not threadlocked but may be tight, The foremost screw can be removed that allows the retainer ring (D") holding the front lens cell in to then be spun out, giving you access to the inner surfaces and the aperture iris. The three rear screws can be loosened if you need to slide out the aperture mechanism and/or adjust the iris. All the screws have threadlocker and so will need to have acetone applied prior to removal. Edited February 14 by BrianSVP Link to post Share on other sites More sharing options...
