Love my M8; now I need another lens.
ardbeg
So, as mentioned above, I just got a pre-ASPH 50 lux. Any need to get it coded or should I just stick to worrying about coding at 35mm and wider? Will be doing a combination of b&w and color work.
--Lawson
Don't worry about coding it until and unless you see a problem with cyan drift. You probably will not. Have you read the review of 50s?
Cheers,
Cheers,
I did read the 50s review (very nice article btw) which was why I was leaning toward not coding however your article didn't specifically cover the pre-ASPH nor any 1.102 corner handling changes so I thought I'd re-confirm. Thanks.
--Lawson
First victim of the new lens.
--Lawson
--Lawson
I have the preASPH and it's the only lens I have not coded. While I'd like the convenience of not having to switch the menu to non-coded every time I mount the lens and have the lens info in the exif -there are no functional problems with using it uncoded. Cyan drift and vignetting are non issues with the 50. So as I really don't want to loose the lens for a month and take a chance on the focus getting screwed up I think I'll just leave it as is.
--Lawson
Thanks.
In general, the need to code or not code (for cyan drift correction) varies mostly by focal length and not so much among specific lenses of a given nominal focal length. ie: 35s benefit from it, 50s don't necessarily.
Cheers,
Sean
