mdg1371 Posted December 21, 2019 Share #1 Posted December 21, 2019 (edited) Advertisement (gone after registration) Got my SL2 a couple days ago, just got down to configuring it, and I am running into the following: ISO set to auto---Auto ISO will not move off 100-- I am using M lenses on a Hawk's helical M to L adapter. I am assuming it may be the uncoded adapter, as this also prevented activation of IBIS until I chose a lens profile. Has anyone else run into this. or am I missing something simple? Edited December 21, 2019 by mdg1371 Link to post Share on other sites More sharing options...
Advertisement Posted December 21, 2019 Posted December 21, 2019 Hi mdg1371, Take a look here SL2 Auto ISO fixed at ISO 100 . I'm sure you'll find what you were looking for!
LikameLeica Posted December 21, 2019 Share #2 Posted December 21, 2019 Using Leica L to M adapter with no issues with several M lenses, so you may be correct in that it is the Hawk's adapter. Link to post Share on other sites More sharing options...
mdg1371 Posted December 21, 2019 Author Share #3 Posted December 21, 2019 23 minutes ago, LikameLeica said: Using Leica L to M adapter with no issues with several M lenses, so you may be correct in that it is the Hawk's adapter. I think so, if you remove the adapter and put nothing on the lens mount, it stays at 100 also -- so ISO must be coding dependent. Odd, the M10 does not behave like that with uncoded lenses mounted. Link to post Share on other sites More sharing options...
kitreyes Posted September 19, 2021 Share #4 Posted September 19, 2021 Did you ever figure out a solution? I’m having the same problem now with the SL2-S and the Novoflex adapter Link to post Share on other sites More sharing options...
LeicaR10 Posted September 19, 2021 Share #5 Posted September 19, 2021 Kitreyes, It could be your adapter or simply do a camera reset from the Menu. I had other issues with the SL2, but it appears a Reset often clears the bug. Try it. r/ Mark Link to post Share on other sites More sharing options...
frame-it Posted September 19, 2021 Share #6 Posted September 19, 2021 On 12/22/2019 at 12:58 AM, mdg1371 said: so ISO must be coding dependent never heard of anything like this before..please explain in detail. Link to post Share on other sites More sharing options...
kitreyes Posted September 19, 2021 Share #7 Posted September 19, 2021 Advertisement (gone after registration) 1 hour ago, LeicaR10 said: Kitreyes, It could be your adapter or simply do a camera reset from the Menu. I had other issues with the SL2, but it appears a Reset often clears the bug. Try it. r/ Mark Tried a reset but the problem remains. FYI the Auto ISO is only stuck at 100 in P and A modes. In M and S modes it works fine. What gives? Link to post Share on other sites More sharing options...
LeicaR10 Posted September 19, 2021 Share #8 Posted September 19, 2021 Kitreyes, I sent you a PM. r/ Mark Link to post Share on other sites More sharing options...
rickatwoodme Posted December 9, 2021 Share #9 Posted December 9, 2021 Maybe you need to manually code the lens on the camera body; on my SL 601, I have to set a lens profile for A priory to work and with my Voigtlander lenses as they are not coded, even with the Leica M-L Adapter; This page has a great list of equivalents: https://lavidaleica.com/content/leica-lens-codes Link to post Share on other sites More sharing options...
msh58 Posted December 11, 2021 Share #10 Posted December 11, 2021 Am 18.9.2021 um 23:24 schrieb kitreyes: Tried a reset but the problem remains. FYI the Auto ISO is only stuck at 100 in P and A modes. In M and S modes it works fine. What gives? How can you use P and S modes with a lens whose aperture cannot be controlled by the camera body?? 2 Link to post Share on other sites More sharing options...
Photoworks Posted December 11, 2021 Share #11 Posted December 11, 2021 27 minutes ago, msh58 said: How can you use P and S modes with a lens whose aperture cannot be controlled by the camera body?? You don’t use P and S with M lenses ! If you use a Leica adapter you would see only M and A available 3 Link to post Share on other sites More sharing options...
msh58 Posted December 12, 2021 Share #12 Posted December 12, 2021 Am 11.12.2021 um 14:57 schrieb Photoworks: You don’t use P and S with M lenses ! If you use a Leica adapter you would see only M and A available That's what I thought. The message from kitreyes was confusing in that sense. Link to post Share on other sites More sharing options...
satijntje Posted July 16, 2023 Share #13 Posted July 16, 2023 Just bumping this old thread up again. Experimenting with SL2 and some antique silverchrom M lenses from the fifties. Using the original L-M Leica Adapter and the camera ist set to Aperture mode. Is it normal that with some uncoded M lenses the Auto-ISO stays at 100? In my case it is an old Summaron and the SL2 did not ask me which lens is was; no Auto-ISO. For the rigid Summicron, the camera asks to identify the lens and auto ISO works fine. With 6bit coded M lenses the Auto-ISO works as well. Some strange things…… 🙂 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/304618-sl2-auto-iso-fixed-at-iso-100/?do=findComment&comment=4815521'>More sharing options...
satijntje Posted July 16, 2023 Share #14 Posted July 16, 2023 Strange, after I switched the camera 2x on and off, and attached other lenses and the Summaron back again, the Auto ISO is working now after the camera asked me to indentify the lens. 1 Link to post Share on other sites More sharing options...
