caissa Posted December 10, 2019 Share #1 Posted December 10, 2019 (edited) Advertisement (gone after registration) On the SL I adapted lenses from many different brands. My favorites are R lenses and Contax lenses, but also Nikon and Canon specialty lenses are useful. Here we could collect experiences (good or bad) with adapted lenses. Edited December 10, 2019 by caissa Link to post Share on other sites More sharing options...
Advertisement Posted December 10, 2019 Posted December 10, 2019 Hi caissa, Take a look here Leica SL2 and adapted lenses. I'm sure you'll find what you were looking for!
caissa Posted December 10, 2019 Author Share #2 Posted December 10, 2019 (edited) Unfortunately I have to start with a small problem. I tried to adapt a Contax 28mm lens to the SL2. As with the SL I did not use the expensive R to L adapter (original from Leica). but used the combination of two adapters. Contax to M adapter and the official M to L adapter. When I did that on the SL I got a list of Leica lenses to choose from. I could select between M and R lenses. Now on the SL2, I get only a list of M lenses to choose from. Do other users get the same experience ? Is this a user error or a problem of the early firmware ? Thanks for any answer. I will see if I get a better result when adapting an original R lens with the adapter pair. (Or if I need to buy the expensive original R to L adapter to get access to the list of R lenses). Edited December 10, 2019 by caissa Link to post Share on other sites More sharing options...
caissa Posted December 10, 2019 Author Share #3 Posted December 10, 2019 (edited) Now I tried a R lens adapted with the adapter pair consisting of original R to M adapter plus original M to L adapter. And now I get the list of R lenses to choose from (only the R). Which is ok. But for foreign lenses it would be useful to be able to select from both R and M lenses. Many SLR lenses have siblings in the R collection. (especially longer lenses). I have to check again, if I get a list of both lens types, as you just described .... Edited December 10, 2019 by caissa Link to post Share on other sites More sharing options...
gbealnz Posted December 10, 2019 Share #4 Posted December 10, 2019 I might be barking up the wrong tree here, but when I had my SL (sadly no more), I used the genuine M lens to L mount, and then a generic (e bay) R lens to M mount adapter. This generic adapter had the "6-bit" pits on the rear, and it was a matter of selecting the correct "pit" to blacken. Once I did this it bought up the R lens menus. Maybe this is the problem you face? Gary Link to post Share on other sites More sharing options...
