wda Posted November 18, 2019 Share #21 Â Posted November 18, 2019 Advertisement (gone after registration) 14 minutes ago, jaapv said: Don't trust the thing too much - that is an old Selenium meter - it is unlikely to be anywhere near accurate, if it is still working. I believe the cells can still be replaced by an independent repairer. But I see no need to use such a meter with the CL. Link to post Share on other sites More sharing options...
Advertisement Posted November 18, 2019 Posted November 18, 2019 Hi wda, Take a look here ISO Settings. I'm sure you'll find what you were looking for!
Le Chef Posted November 18, 2019 Author Share #22 Â Posted November 18, 2019 I guess I was just going a bit steam punk on the light meter! Link to post Share on other sites More sharing options...
geoffreyg Posted November 18, 2019 Share #23  Posted November 18, 2019 Always set the ISO. Look at the three together - shutter speed, f stop and ISO, and make the choices. Usually 400 in daylight, 1600 in dark, 800 if I can get away with it. Only 3200 in must-have situations. Keep it simple rule in effect.  1 Link to post Share on other sites More sharing options...
caigy Posted November 18, 2019 Share #24  Posted November 18, 2019 Aperture priority and ISO 100 90% of the time, until shutter speed drops too low for steady handholding. I want to preserve the dynamic range ability of the sensor, which is always best at base ISO. On rare occasions when I need higher ISO, I will try setting to 400 or 800 to get shutter speed up a bit. Once in a great while I will use Auto ISO (with upper limit of 6400) but usually only in very dim conditions, which mostly means at night. I've found that quality is actually pretty decent up to 6400, but I don't like the camera's algorithm, which under Auto ISO will push it up there much sooner than I would prefer. 2 Link to post Share on other sites More sharing options...
colonel Posted November 21, 2019 Share #25 Â Posted November 21, 2019 I used to always set ISO manually, thinking auto-ISO was the work of the devil ;;; But recently I have been using it on all my cameras. Basically you need to think what your objective is. Mine is sharpness and focus. The sensors are so good now that up to 1600 on most cameras, 3200 on most APS-C and 6400 on most FF is acceptable On the CL I set maximum ISO is 6400 on any lens above f2. On the 23mm f2 and 35mm f1.4 I normally set it at 3200 The key issue is that the lowest speed depends on what I am shooting. I prefer a minimum of 1/160 when doing street during the day, unless I want to blur people's movement. For night shooting I tend to use 1/3fl or 1/4fl On aperture priority and auto-ISO, all I need to think about is the framing, focus and aperture. Perfect !! Link to post Share on other sites More sharing options...
mikbau Posted November 22, 2019 Share #26 Â Posted November 22, 2019 On 11/18/2019 at 2:21 AM, M10 for me said: That is somehow difficult to understand. Mainly in dim light I change to Auto (with the M though) unless I have the camera on the tripod and take my time to set all variables. Normally I have no tripod. Well, frankly, I don't use any auto settings - including ISO. I never have. I prefer to have full control (and yes, I know you can set the max ISO) - it's just not how I shoot Link to post Share on other sites More sharing options...
