syam Posted June 10, 2020 Author Share #21 Posted June 10, 2020 (edited) Advertisement (gone after registration) Just wanted to update this after several months. I'm still using version 2 of the 3D printed case. It has been through everything including hikes, road trips, daily shooting, family stuff. Definitely less than pre-quarantine, but still used quite a bit. I've made some refinements and plan to print a new case in the coming weeks. Minor changes for this V3 are: - Reducing the round size of the corners - Reducing wall thickness from 3mm to 2mm - Adding a hole for the focus LED - Adding more room around the on/off switch - Removing the Leica script branding on the top cover plate - Adding more space around the rear buttons and increasing the cutout size - Adding in interior cutouts for felt material to sit against the Q body - Removing the leash strap ring on the bottom of the case I'll be printing the new case using PET-G instead of PLA, so durability should be better than before (not that I ever dropped it). The eventual plan is still to have the case machined out of aluminum and anodized black to match the OE Leica Q finish, but that will wait until the design has been completely finalized. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited June 10, 2020 by syam 2 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/299948-my-first-leica-q-designing-a-case/?do=findComment&comment=3990994'>More sharing options...
Advertisement Posted June 10, 2020 Posted June 10, 2020 Hi syam, Take a look here My first Leica Q. Designing a case. . I'm sure you'll find what you were looking for!
Javier_L Posted June 12, 2020 Share #22 Posted June 12, 2020 (edited) Good news then. Could you share the updated file? Thank you. Edited June 12, 2020 by Javier_L Link to post Share on other sites More sharing options...
syam Posted June 12, 2020 Author Share #23 Posted June 12, 2020 Uploaded the files to my Thingiverse page. https://www.thingiverse.com/thing:4457464https://www.thingiverse.com/thing:4457464 I'll continually be making changes to the case over time so if there are any suggestions, please post here so we can start a discussion. Big changes that I want to make in the future: - Add an ARCA plate adapter - Add finger cutouts for the front hand grip - Redo the lip/groove features - Add some snap hooks so the top and bottom halves click together - Print again using PET-G and soluble support - Eventually CNC out of aluminum (2mm wall thickness) and hard anodize matte black. 2 Link to post Share on other sites More sharing options...
fm13 Posted January 7, 2021 Share #24 Posted January 7, 2021 (edited) such a great idea! Probably an absurd question: How feasible is a full body cover that only leaves the lens opening, shutter button and display uncovered? Sometimes, when it snows or drizzles, it would be nice to prepare the settings indoors, put on a cover and go out to shoot. On 6/12/2020 at 11:24 PM, syam said: Uploaded the files to my Thingiverse page. https://www.thingiverse.com/thing:4457464https://www.thingiverse.com/thing:4457464 I'll continually be making changes to the case over time so if there are any suggestions, please post here so we can start a discussion. Big changes that I want to make in the future: - Add an ARCA plate adapter - Add finger cutouts for the front hand grip - Redo the lip/groove features - Add some snap hooks so the top and bottom halves click together - Print again using PET-G and soluble support - Eventually CNC out of aluminum (2mm wall thickness) and hard anodize matte black. Edited January 7, 2021 by fm13 Link to post Share on other sites More sharing options...
PhotoCruiser Posted January 7, 2021 Share #25 Posted January 7, 2021 Basically a good project and i am sure some people would use it. What i suggest is to drop the milled aluminum or brass housing for price, shock absorbtion and weight reasons and use a reasonable soft plastic with a good haptic feeling to keep or expand the high quality finish and appearance of a Leica camera. Chris Link to post Share on other sites More sharing options...
syam Posted January 7, 2021 Author Share #26 Posted January 7, 2021 5 hours ago, fm13 said: such a great idea! Probably an absurd question: How feasible is a full body cover that only leaves the lens opening, shutter button and display uncovered? Sometimes, when it snows or drizzles, it would be nice to prepare the settings indoors, put on a cover and go out to shoot. Hey fm13, A full body cover with only the necessities exposed would not be difficult to design and print, but at the same time would probably provide little real protection. My reasoning is the seams around the shutter, being on the top, is most likely the highest risk for ingress, along with the moving parts of the lens. I've toyed with the idea of doing this with actual seals and 'press through' rubber buttons but have a ton on my plate for work and other side projects. 1 Link to post Share on other sites More sharing options...
syam Posted January 7, 2021 Author Share #27 Posted January 7, 2021 (edited) Advertisement (gone after registration) 4 hours ago, PhotoCruiser said: Basically a good project and i am sure some people would use it. What i suggest is to drop the milled aluminum or brass housing for price, shock absorbtion and weight reasons and use a reasonable soft plastic with a good haptic feeling to keep or expand the high quality finish and appearance of a Leica camera. Chris Hi Chris, Thanks for the input. I have not toyed around with the idea of 3D printing in a flexible material, but that would be a good idea for texture/feel and also weight. The only issue would be securing the top and bottom halves together and/or designing it to stretch open. If I get time in the future I may try to design for these considerations and also experiment with flexible filaments and/or other 3D printing technologies that do not break the bank. As an aside, I've been taking fewer pictures the past 6 months, but the Q has still been stellar every time I use it. I've been using the same 3D printed case from several months back and it's been great. I do have several improvements in mind but being busy at work, buying a new old house, life has left me with very little time for additional side projects. Edited January 7, 2021 by syam 3 Link to post Share on other sites More sharing options...
Javier_L Posted June 17, 2021 Share #28 Posted June 17, 2021 Link is not working, loved your work. Could you share it again? THK. Link to post Share on other sites More sharing options...
